Turn a SATA host connection into an mSATA port. The SAT32MSATM SATA to mSATA adapter enables you to connect an mSATA SSD to any standard SATA port, ideal for connecting an mSATA SSD to an ITX computer systems that does not have an mSATA port.
The adapter enables you to harness the speed of upgrading to a faster drive by connecting an mSATA SSD to any SATA-enabled desktop computer. Allowing for faster boot time, and increased performance in regular operation.
For a hassle-free, tool-less installation where space may be limited the adapter connects and mounts directly into the SATA port.
- StarTech.com SATA to mSATA SSD Adapter - Port Mounted SATA to Mini SATA Drive Converter Card - 7-Pin SATA to mSATA Adapter Converter Card (SAT32MSATM) - storage controller - SATA 6Gb/s
- Storage controller - internal
- Hard Drive Form Factor Compatibility
- mSATA
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 17 cm x 14.2 cm x 3 cm
- 14 g
- 2-year warranty
- mSATA
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 1 x SATA 6Gb/s - mSATA
- Connections
- 1 x SATA 6Gb/s - 7 pin Serial ATA , 1 - 4 PIN internal power
- Included Accessories
- Power 15 pin SATA to 4 pin adapter
- FCC, RoHS
- Limited warranty - 2 years
- 17 cm
- 14.2 cm
- 3 cm
- 14 g
- 5 °C
- 50 °C
- 20 - 80%
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.40 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.40 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.36 |
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F | In Stock | £6.02 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £37.78 |
StarTech.com 1 Port SATA to eSATA Slot Plate Bracket | In Stock | £6.50 |
StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card | In Stock | £14.35 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £18.53 |
StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe | In Stock | £152.39 |
