StarTech.com SATA to LP4 with 2x SATA Power Splitter Cable
Quicklinx: 745RWS00 Mfr#: PYOLP42SATA
This SATA power splitter cable features an extra LP4 power connector. The SATA power splitter connects to a single SATA power supply connection and breaks out into two SATA female power connectors and one LP4 connector - adding one LP4 and one SATA power connection, without having to upgrade the PSU or limit the number of installed drives based on power connection availability.
StarTech.com SATA to LP4 with 2x SATA Power Splitter Cable - Power splitter - SATA power (M) to 4 pin internal power, SATA power (F) - 6 in - PYOLP42SATA - power splitter - 15.2 cm
Power splitter
Length
15.2 cm
Connectors
15 pin Serial ATA power - male
Connectors (Second End)
2 x 15 pin Serial ATA power - female , 4 PIN internal power - female
Power splitter
Length
15.2 cm
Connectors
RoHS
