Power up to 3 devices using a SATA power connector from the computer power supply.
The LP4SATAFM2L SATA to LP4 Power Cable lets you power an IDE (LP4-connected) drive using a SATA power connector from the computer power supply. The adapter features two additional LP4 power connectors, offering the versatility to connect two additional (LP4 connected) drives (CD/DVD-ROM, HDD, etc.) using the same single connection to the computer power supply.
This high quality LP4/SATA power adapter cable is expertly designed for durability.
- StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4 - Power adapter - 4 pin internal power (F) to SATA power (M) - 5.9 in - black - LP4SATAFM2L - power adapter - 4 PIN internal power to SATA power - 15 cm
- Power adapter
- Length
- 15 cm
- Connector
- 3 x 4 PIN internal power - female
- Connector (Second End)
- 15 pin Serial ATA power - male
- Black
- Limited lifetime warranty
- Designed For
- P/N: S25SLOTR, SATSASBP425
- Power adapter
- Length
- 15 cm
- Black
- Connector
- RoHS
- Designed For
