Turn a Compact Flash card into a bootable SATA SSD. This SATA to CF SSD adapter features a SATA male power connector and a SATA male data connector, as well as a Compact Flash port, allowing you to connect a Compact Flash type media card to a laptop computer in place of a serial ATA hard drive.
A do-it-yourself SSD solution, the CF to SATA adapter allows Compact Flash, Compact Flash 2, or MicroDrive media to be used on a notebook computer as a bootable hard drive and requires no software or driver installation.
- StarTech.com SATA to Compact Flash SSD Adapter - CompactFlash Card adapter - SATA
- Interface Type
- SATA
- 20 g
- 2-year warranty
- Designed For
- P/N: SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SU2DUPERA11
- Interface Type
- SATA
- 20 g
- Expansion Slots
- 1 x CompactFlash Card - type I/II
- Connections
- 1 x storage - SATA 1.5Gb/s - 22 pin Serial ATA
- FCC, RoHS
- Limited warranty - 2 years
- Designed For
