StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks
Quicklinx: 7P1VWS00 Mfr#: SAT2IDEADP
More than 50 in stock
£17.52 ex VAT
£21.02 inc VAT
The SAT2IDEADP SATA to IDE hard drive adapter allows for 2.5in/3.5in IDE-based (PATA) hard drives (HDD) to be used in most StarTech.com SATA-based HDD docking stations and drive duplicators. The unique mounting style of the SATA/IDE adapter enables it to be easily mounted to IDE/ATA hard drive and inserted into SATA hard drive dock bay, for quick and easy retrieval of data from older HDDs while its all- metal construction ensures maximum durability. The SAT2IDEADP hard drive adapter works with most StarTech.com SATA HDD Docking Stations and Duplicators, including: SATADOCK22UE, SATDOCK2UEGB, SATDOCK22RE, SATDOCK22R, SATDOCKU3S, SATADOCKU2, SATADOCKU2E, SATDOCK4U2E, SATDOCK4U3E, SATDOCKCRH, SATDOCKU2EGB, SATDOCKU2GB. Fully compatible with both 2.5in and 3.5in form factor hard drives and up to ATA-133 (133 MBps), this versatile HDD adapter can also be used to install IDE hard drives into SATA-only desktop computers, or many other scenarios that require an IDE HDD be connected through SATA.
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks - SATA to IDE Converter - HDD Docking Station (SAT2IDEADP) - storage controller - ATA-133 - SATA
Storage controller - internal
Bus Type
SATA
Hard Drive Form Factor Compatibility
2.5", 3.5"
ATA-133
Data Transfer Rate
133 MBps
Supported Devices
Hard drive
Channel Qty
1
7.8 cm x 10.1 cm x 2.6 cm
104 g
P/N: SATDOCK2REU3, SATDOCK4U3RE, SATDOCK5U3ER, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U313, SDOCK4U33, SDOCKU313, SDOCKU313E, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, SDOCKU33HW, SU2DUPERA11, UNIDOCKU33
2.5", 3.5"
Host Bus
SATA
Storage Controller
ATA-133
Data Transfer Rate
133 MBps
Supported Devices
Hard drive
Channel Qty
1
1 x ATA-133 - 40 PIN IDC
1 storage - Serial ATA-150 - 7 pin Serial ATA
FCC, RoHS
Limited warranty - 2 years , Technical support - lifetime
7.8 cm
10.1 cm
2.6 cm
104 g
5 °C
80 °C
8 - 90%
P/N: SATDOCK2REU3, SATDOCK4U3RE, SATDOCK5U3ER, SATDOCKU3S, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U313, SDOCK4U33, SDOCKU313, SDOCKU313E, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, SDOCKU33HW, SU2DUPERA11, UNIDOCKU33
7P1V StarTech.com 40 Pin Female IDE to SATA Adapter Converter In Stock £10.91
7P1V StarTech.com Bi-Directional SATA IDE Adapter Converter In Stock £9.83
7P1V StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £29.00
7P1V StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £17.52
Price Range Ex VAT: 0 - 50
