StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks
Quicklinx: 7P1VWS00 Mfr#: SAT2IDEADP
£19.65 ex VAT
£23.58 inc VAT
The SAT2IDEADP SATA to IDE hard drive adapter allows for 2.5in/3.5in IDE-based (PATA) hard drives (HDD) to be used in most StarTech.com SATA-based HDD docking stations and drive duplicators. The unique mounting style of the SATA/IDE adapter enables it to be easily mounted to IDE/ATA hard drive and inserted into SATA hard drive dock bay, for quick and easy retrieval of data from older HDDs while its all- metal construction ensures maximum durability. The SAT2IDEADP hard drive adapter works with most StarTech.com SATA HDD Docking Stations and Duplicators, including: SATADOCK22UE, SATDOCK2UEGB, SATDOCK22RE, SATDOCK22R, SATDOCKU3S, SATADOCKU2, SATADOCKU2E, SATDOCK4U2E, SATDOCK4U3E, SATDOCKCRH, SATDOCKU2EGB, SATDOCKU2GB. Fully compatible with both 2.5in and 3.5in form factor hard drives and up to ATA-133 (133 MBps), this versatile HDD adapter can also be used to install IDE hard drives into SATA-only desktop computers, or many other scenarios that require an IDE HDD be connected through SATA.
  • Versatile compatibility
    The adapter supports both 2.5-inch and 3.5-inch hard drives, making it versatile for various storage needs.
  • Efficient data handling
    With a data transfer rate of 133 MBps, this controller ensures efficient data management and quicker access time.
  • Robust environmental tolerance
    It operates effectively in temperatures ranging from 5°C to 80°C and a humidity level of 8 to 90%, making it reliable in diverse conditions.
  • Compliant with standards
    The product adheres to FCC and RoHS standards, ensuring quality while being environmentally friendly.
  • Internal storage efficiency
    Designed for internal use, the adapter is perfect for integrating into existing systems for enhanced storage capabilities.
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks - SATA to IDE Converter - HDD Docking Station (SAT2IDEADP) - storage controller - ATA-133 - SATA
Storage controller - internal
Bus Type
SATA
Hard Drive Form Factor Compatibility
2.5", 3.5"
ATA-133
Data Transfer Rate
133 MBps
Supported Devices
Hard drive
Channel Qty
1
7.8 cm x 10.1 cm x 2.6 cm
104 g
P/N: SATDOCK2REU3, SATDOCK4U3RE, SATDOCK5U3ER, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U313, SDOCK4U33, SDOCKU313, SDOCKU313E, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, SDOCKU33HW, SU2DUPERA11, UNIDOCKU33
2.5", 3.5"
Host Bus
SATA
Storage Controller
ATA-133
Data Transfer Rate
133 MBps
Supported Devices
Hard drive
Channel Qty
1
1 x ATA-133 - 40 PIN IDC
1 storage - Serial ATA-150 - 7 pin Serial ATA
FCC, RoHS
Limited warranty - 2 years , Technical support - lifetime
7.8 cm
10.1 cm
2.6 cm
104 g
5 °C
80 °C
8 - 90%
P/N: SATDOCK2REU3, SATDOCK4U3RE, SATDOCK5U3ER, SATDOCKU3S, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U313, SDOCK4U33, SDOCKU313, SDOCKU313E, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, SDOCKU33HW, SU2DUPERA11, UNIDOCKU33
7P1V StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.88
7P1V StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £43.30
7P1V StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.65
7P1V StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £20.49
7P1V StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable In Stock £23.61
