StarTech.com SATA Dual Hard Drive RAID Adapter - SATA to Dual SATA HDD RAID Controller Card
Quicklinx: 9PSBWS00 Mfr#: S322SAT3R
Connect two SATA Hard Drives to a single internal SATA connection, and build a RAID array for accelerated performance or secure data redundancy. The S322SAT3R internal drive-mounted SATA RAID adapter lets you connect two SATA hard drives to a single SATA connector on your motherboard, and build a hardware RAID array.
This versatile RAID adapter features a built-in hardware RAID controller, supporting JBOD, BIG, RAID 0, and RAID 1 - to achieve greater drive capacity, secure data redundancy or improved system performance.
With two included SATA cables you'll have everything you need to ensure a hassle-free installation. This plug-and-play HDD adapter is easy to install, mounting directly to your drive without any additional hardware or software installation.
To ensure compatibility with your computer system, the S322SAT3R supports all of the leading operating systems, including: Microsoft Windows (8/7/Vista/XP/Server 2008/Server 2003), Apple OSX (10.9/10.8/10.7/10.6), Linux, and Google Chrome OS .
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD RAID controller supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
StarTech.com SATA Dual Hard Drive RAID Adapter - Internal SATA Connector to Dual SATA HDD RAID Controller Card - storage controller - eSATA 6Gb/s - SATA 6Gb/s
Storage controller - internal
Bus Type
SATA 6Gb/s
eSATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD
2.3 cm x 7.4 cm x 2.5 cm
10 g
Host Bus
SATA 6Gb/s
Storage Controller
eSATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
2
RAID Level
JMicron JMS562
2 x eSATA 6Gb/s - eSATA
FCC, RoHS
2.3 cm
7.4 cm
2.5 cm
10 g
5 °C
50 °C
20 - 80%
