This S-Video or composite to HDMI® converter with audio lets you connect an S-Video or analog composite device, along with supporting RCA L/R audio, to your HDMI monitor or television.
Equipped with an on-screen display (OSD) menu and convenient selector switches for easy configuration, this compact S-Video or composite to HDMI video converter installs quickly and easily, for a true plug-and-play experience.
This HDMI upscaler is able to function with both NTSC and PAL systems, and offers support for output resolutions up to 720p to seamlessly integrate with almost any display.
By using this analog to HDMI converter you'll be able to continue using your legacy equipment (video camera, DVD player, etc.) with your HDMI display or monitor, ultimately saving the costs of upgrading your equipment. It's ideal for boardroom settings, medical imaging and watching old home videos on your HD display or television.
This AV (audio video) converter box features an integrated RCA L/R audio connection that combines the audio and video inputs into a single HDMI output, avoiding the hassle of running a separate audio cable to your destination display.
Versatile input options
Accommodates S-Video and composite video inputs, along with audio line-in, providing flexibility for various media connections. -
Clear output resolution
Delivers a maximum resolution of 1280 x 720, ensuring that visuals are sharp and well-defined when connected to HDMI displays. -
Reliable temperature range
Operates effectively between 0°C and 45°C, ensuring operational reliability in diverse environments. -
User-friendly features
Includes an LED indicator for status monitoring and an OnScreenDisplay (OSD) for navigation and settings adjustment. -
Included power adapter
Comes with a power adapter for easy Plug-and-Play setup, enhancing user convenience right out of the box.
- StarTech.com S-Video or Composite to HDMI Converter with Audio - 720p - video converter - black
- Video converter
- Max Resolution
- 1280 x 720
- 1 x HDMI output - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 1 x composite video input - RCA
- 7.1 cm x 15.5 cm x 2.3 cm
- Enclosure Colour
- Black
- Video converter
- Max Resolution
- 1280 x 720 at 60 Hz
- OnScreenDisplay (OSD), LED indicator
Video Output
- Analogue Video Format
- PAL, NTSC 3.58
- Voltage Required
- AC 120/230 V
- 2.5 Watt
- Included Accessories
- Power adapter
- 7.1 cm
- 15.5 cm
- 2.3 cm
- 252 g
- Shipping Width
- 20 cm
- Shipping Depth
- 25 cm
- Shipping Height
- 6 cm
- Shipping Weight
- 395 g
- Enclosure Colour
- Black
- 0 °C
- 45 °C
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £8.55 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.94 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.01 |
