StarTech.com S-Video / Composite to USB Video Capture Cable w/ TWAIN and Mac Support
Quicklinx: 7P3KWS00 Mfr#: SVID2USB23
  • Windows 8 (32/64 bits)
Capture and convert an S-Video or Composite video on your PC or Mac as digital media. The SVID2USB23 USB 2.0 S-Video & Composite Video Capture Cable offers an easy to use analog video capture solution, enabling you to grab video from an S-Video or Composite video source, as well as the accompanying 2-channel RCA audio, to your Mac or Windows computer.
The cable connects to your desktop or laptop computer through USB 2.0, and is compact enough to fit in the palm of your hand, providing a conveniently portable video capture solution that's more than suitable for use with laptops and desktop computers alike.
An easy-to-use device for recording analog video to your computer from external sources, such as a VCR or camcorder the SVID2USB23 offers the perfect solution for Betamax or VHS video capture, with real-time MPEG-1, MPEG-2, and MPEG-4 encoding, as well as TWAIN support, to ensure compatibility with a wide range of systems and software.
StarTech.com Composite to USB Video Capture - S Video Converter / Analog to Digital Video Adapter with TWAIN and Mac Support (SVID2USB23) - video capture adapter - USB 2.0
Video capture adapter
Interface Type
USB 2.0
60 g
Video Input
S-video input, composite video input
Analogue Video Format
NTSC, SECAM, PAL
Analogue video Signal
S-Video, composite video
Digital Video Format
MPEG-1, MPEG-2
Digital Video Capture Resolution
720 x 480, 720 x 576
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
1-year warranty
Interface Type
USB 2.0
60 g
Video
Interface Type
NTSC, SECAM, PAL
MPEG-1, MPEG-2
1 x display / video - composite video input - RCA , 1 x display / video - S-video input - 4 pin mini-DIN , 1 x audio - input - RCA x 2
1 x USB 2.0 - 4 pin USB Type A
Plug and Play, FCC
Software Included
Drivers & Utilities
Limited warranty - 1 year
50 °C
5 - 85% (non-condensing)
