Connect USB 10Gbps source and peripheral devices, using this 3.3ft (1m) Rugged Right Angle USB Type-C Cable. Position the right angle USB-C connection along the device to reduce cable clutter and avoid prolonged strain from bending. It is ideal for 10Gbps data transfer to external USB-C-enabled external storage devices, or as a single-cable connection from a USB-C dock to a laptop.
Experience 4K Video with DisplayPort 1.2 Alt Mode
The Rugged USB-C cable supports up to 4K 60Hz video over DisplayPort 1.2 Alt Mode, and is compatible with 1080p and lower resolutions. -
Enhanced Durability
Designed to withstand heavy use, the USB-C cable features an Aramid fiber core and durable TPE outer jacket. This heavy-duty construction protects against fraying or breakage and resists tangling. -
Full-Featured USB-C Power and Data
This USB Type-C cable features Power Delivery (PD) 3.0 with up to 100W PD output. Power and charge a USB-C laptop, such as Apple MacBook, Lenovo ThinkPad, or Microsoft Surface with up to 100W output over USB Power Delivery 3.0. Connect the USB-C cable from a laptop to a USB-C wall charger or docking station.
- StarTech 3ft (1m) Rugged Right Angle USB-C Cable, USB 10 Gbps, USB C to C Data Transfer Cable, 4K 60Hz DP Alt Mode, 100W Power Delivery - 90 Degree USB-C Cable (RUSB31CC1MBR) - USB-C cable - USB-C to USB-C - 1 m
- USB-C cable
- Technology
- Shielded
- Passive adapter, 4K60Hz support, rugged, strain relief, halogen free, e-marker chip, up to 100 Watts of power delivery, 10 Gbps data rate, DisplayPort Alternate Mode 1.2 support
- Cable Length
- 1 m
- Connector
- 24 pin USB-C - male - straight
- Connector (Second End)
- 24 pin USB-C - male - right-angled
- USB 3.2 Gen 2
- Black
- 2-year warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- Plated Connector
- Gold, nickel
- Cable Length
- 1 m
- Outside Diameter
- 4.8 mm
- Black
- Connector
- USB 3.2 Gen 2, RoHS, WEEE, EMI
- Shipping Width
- 12.8 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.4 cm
- Shipping Weight
- 95 g
- 2-year warranty
