StarTech.com Rugged Right Angle USB-C Cable 0.5m
Quicklinx: HFP6WS00 Mfr#: RUSB31CC50CMBR
Length: 0.5m
10 In Stock
£25.87 ex VAT
£31.04 inc VAT
Connect USB 10 Gbps source and peripheral devices, using this 1.6ft (50cm) Rugged Right Angle USB Type-C Cable. Position the right angle USB-C connection along the device to reduce cable clutter and avoid prolonged strain from bending. It is ideal for 10 Gbps data transfer to external USB-C-enabled external storage devices, or as a single-cable connection from a USB-C dock to a laptop.
  • Experience 4K Video with DisplayPort 1.2 Alt Mode
    The Rugged USB-C cable supports up to 4K 60Hz video over DisplayPort 1.2 Alt Mode, and is compatible with 1080p and lower resolutions.
  • Enhanced Durability
    Designed to withstand heavy use, the USB-C cable features an Aramid fiber core and durable TPE outer jacket. This heavy-duty construction protects against fraying or breakage and resists tangling.
  • Full-Featured USB-C Power and Data
    This USB Type-C cable features Power Delivery (PD) 3.0 with up to 100W PD output. Power and charge a USB-C laptop, such as Apple MacBook, Lenovo ThinkPad, or Microsoft Surface with up to 100W output over USB Power Delivery 3.0. Connect the USB-C cable from a laptop to a USB-C wall charger or docking station.
StarTech.com 1.6ft (50cm) Rugged Right Angle USB-C Cable, USB 3.2 Gen 2 (10 Gbps), USB C to C Data Transfer Cable, 4K 60Hz DP Alt Mode, 100W Power Delivery - 90 Degree USB-C Cable (RUSB31CC50CMBR) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 50 cm
USB-C cable
Shielded
4K60Hz support, rugged, strain relief, halogen free, e-marker chip, up to 100 Watts of power delivery, 10 Gbps data rate, DisplayPort Alternate Mode 1.2 support
Length
50 cm
Connector
24 pin USB-C - male - straight
Connector (Second End)
24 pin USB-C - male - right-angled
USB 3.2 Gen 2
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
Plated Connector
Nickel
Length
50 cm
Outside Diameter
4.8 mm
Connector
USB 3.2 Gen 2, RoHS, WEEE, EMI
Shipping Width
12.8 cm
Shipping Depth
22 cm
Shipping Height
1.4 cm
Shipping Weight
90 g
Length: 0.5m
