StarTech.com RS422 RS485 Serial DB9 to Terminal Block Adapter
Quicklinx: 6PF9WS00 Mfr#: DB92422
Hurry, only 3 left in stock!
£10.88 ex VAT
£13.05 inc VAT
The DB92422 DB 9 to Terminal Block adapter converts an RS-422 or RS-485 DB 9 male serial connector to a terminal block connector.
The 5-pin 3.5mm Terminal Block connector supports screw-type wiring to meet the standard for industrial wiring applications.
  • Versatile connectivity
    The adapter features a 5 pin terminal block on the left side that allows for easy wiring to various serial devices, making it ideal for integrating multiple systems.
  • Robust construction
    Constructed from durable materials, this serial adapter is designed to withstand everyday use in various environments, ensuring reliable performance over time.
  • Simple integration
    With a male 9-pin D-Sub (DB-9) connector, this adapter is compatible with a range of devices, simplifying the process of connecting equipment.
  • Meets compliance standards
    This adapter complies with FCC and RoHS standards, ensuring it adheres to safety regulations and supports environmentally friendly practices.
StarTech.com RS422 RS485 Serial DB9 to Terminal Block Adapter - Serial adapter - 5 pin terminal block to DB-9 (M) - black - DB92422 - serial adapter - 5 pin terminal block to DB-9
Serial adapter
Connector
Connector (Second End)
9 pin D-Sub (DB-9) - male
1-year warranty
P/N: PCI2S232485I, PCI2S4851050
Serial adapter
Connector
FCC, RoHS
1-year warranty
6PF9 StarTech.com 6 ft Professional RS422/485 USB Serial Cable Adapter with COM Retention In Stock £62.27
