The DB92422 DB 9 to Terminal Block adapter converts an RS-422 or RS-485 DB 9 male serial connector to a terminal block connector.
The 5-pin 3.5mm Terminal Block connector supports screw-type wiring to meet the standard for industrial wiring applications.
Versatile connectivity
The adapter features a 5 pin terminal block on the left side that allows for easy wiring to various serial devices, making it ideal for integrating multiple systems. -
Robust construction
Constructed from durable materials, this serial adapter is designed to withstand everyday use in various environments, ensuring reliable performance over time. -
Simple integration
With a male 9-pin D-Sub (DB-9) connector, this adapter is compatible with a range of devices, simplifying the process of connecting equipment. -
Meets compliance standards
This adapter complies with FCC and RoHS standards, ensuring it adheres to safety regulations and supports environmentally friendly practices.
- StarTech.com RS422 RS485 Serial DB9 to Terminal Block Adapter - Serial adapter - 5 pin terminal block to DB-9 (M) - black - DB92422 - serial adapter - 5 pin terminal block to DB-9
- Serial adapter
- Connector
- Connector (Second End)
- 9 pin D-Sub (DB-9) - male
- Black
- 1-year warranty
- Designed For
- P/N: PCI2S232485I, PCI2S4851050
- Serial adapter
- Black
- Connector
- FCC, RoHS
- 1-year warranty
- Designed For
