StarTech.com RS232 to TTL Serial Converter
Quicklinx: B67WWS00 Mfr#: IC232TTL
Easily convert an RS232 serial signal (-12 to +12V) to a transistor-transistor logic signal (0 to +5V). This RS232 to TTL converter lets you connect devices that use RS232 serial ports to devices that only communicate using transistor-transistor logic (TTL) signals. It's a convenient and cost-effective solution to convert RS232 into TTL, so you can connect equipment together based on your devices signal requirements.
This serial converter is ideal for short distance communication between two devices, and can be used to connect your computer to microcontroller-based embedded systems and industrial robotics. The reliable converter easily turns high voltage (-12 to +12V) RS232 signals into low voltage (0 to +5V) TTL signals, and provides bidirectional data communication at baud rates up to 115.2 Kbps.
With a small-footprint design and no software or drivers required, you can easily pair your TTL equipment with virtually any device that features an RS232 DB9 serial port, such as computers, and industrial control equipment. Plus, if your host device doesn't feature a native RS232 port, this versatile converter can be coupled with a USB to RS232 serial adapter (SKU: ICUSB232D - sold separately).
The converter delivers dependable performance at extended operating temperatures (-40°C to 85°C), so it integrates nicely into a variety of workplace settings.
StarTech.com RS232 to TTL Serial Converter - serial adapter - RS-232C
Serial adapter
External
Interface (Bus) Type
Serial RS-232C
3.4 cm x 6.3 cm x 1.5 cm
25 g
RS-232
Data Transfer Rate
115.2 Kbps
Serial adapter
External
Serial RS-232C
Wired
RS-232
Data Transfer Rate
115.2 Kbps
Flow control, full duplex mode
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x RS-232 (TTL) - 9 pin D-Sub (DB-9)
FCC, RoHS
3.4 cm
6.3 cm
1.5 cm
25 g
-40 °C
85 °C
5 - 95%
B67W StarTech.com Slimline Serial DB9 Gender Changer - M/M In Stock £5.38
B67W StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £31.73
B67W StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.85
B67W StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £26.44
B67W StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.02
B67W StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.35
B67W StarTech.com USB to RS232 Serial Adapter In Stock £15.45
