StarTech.com RS232 Serial Null Modem Cable
Quicklinx: H13LWS00 Mfr#: 9FMNM-3M-RS232-CABLE
Length: 3m
Colour: Black
46 In Stock
£7.18 ex VAT
£8.61 inc VAT
3m RS232 Serial Null Modem Cable, Crossover Serial Cable w/Al-Mylar Shielding, DB9 Serial COM Port Cable Female to Male, Compatible w/DTE Devices - Tool-Less Design w/Thumbscrews, Black, F/M (9FMNM-3M-RS232-CABLE).
  • RS232 serial null modem cable
    DB9 male to female serial cable enables a connection between two DTE devices at a distance of up to 3 meters, reducing cable length restrictions and providing flexible serial device setup configuration.
  • Quality construction
    High quality 28 AWG tinned wires with aluminum mylar cable shielding and shielded metal shell connectors prevent EMI interference. Molded PVC connectors with strain reliefs and PVC cable jacket prevent damage due to bends.
  • Screw locking null-modem cable
    This crossover cable features thumbscrews that prevent accidental disconnection which can lead to data loss.
StarTech.com 3m RS232 Serial Null Modem Cable, Crossover Serial Cable w/Al-Mylar Shielding, DB9 Serial COM Port Cable Female to Male, Compatible w/DTE Devices - Tool-Less Design w/Thumbscrews, Black, F/M (9FMNM-3M-RS232-CABLE) - null modem cable - DB-9 to DB-9 - 3 m
Null modem cable
Shielded
Molded, thumbscrews, crossover, strain relief, EMI protection
Length
3 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
9 pin D-Sub (DB-9) - male
Null modem cable
Shielded
Shielding Material
Aluminium mylar foil with drain
Jacket Material
PVC
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
3 m
Outside Diameter
4.8 mm
Connector
RoHS, WEEE, EMI
Shipping Width
22 cm
Shipping Depth
13 cm
Shipping Height
4 cm
Shipping Weight
150 g
Length: 3m
Colour: Black
