StarTech.com RS-232 Serial Ethernet IP Adapter (Device Server, Console Server)
Quicklinx: 4JDWWS00 Mfr#: NETRS232_1GB
Take your serial peripherals to new lengths. With this one-port Ethernet-to-Remote Serial interface converter, your RS-232 serial devices can be placed anywhere on your TCP/IP Ethernet WAN/LAN and still perform as if they were right beside you. It even works over the Internet!
Even at the longest distances, control of your serial devices will be right at your fingertips: the remote serial ports appear alongside your local serial ports in your Windows device manager.
This IP adapter is designed to function seamlessly with your other serial ports for totally transparent operation. Your serial equipment - card scanners, access keypads, bar code scanners, and more - will operate as smoothly as if the serial ports were right inside your computer. For industrial automation, security, Point of Sale, or any time you need reliable, long-range serial communications, this IP adapter delivers superior performance in any environment.
StarTech.com 1 Port RS-232 Serial to IP Ethernet Device Server - device server
Device server
External
United Kingdom
Ethernet, RS-232
Linux, Microsoft Windows 2000 / XP
Device server
Enclosure Colour
Beige
United Kingdom
External
Wired
Data Transfer Rate
115.2 Kbps
Ethernet, RS-232
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP
Remote Management Protocol
Telnet, HTTP
Status Indicators
Transmit, receive
Firmware upgradable
1 x RS-232 - DB-9 , 1 x 10Base-T
UL, FCC
External power adapter
Software Included
Drivers & Utilities, Ether Link Manager
Limited warranty - lifetime
