StarTech.com Rotating Laptop Stand/Riser
Quicklinx: J9X3WS00 Mfr#: ATFR-LAPTOP-RISER
10 In Stock
£51.40 ex VAT
£61.68 inc VAT
This rotating laptop stand raises laptops to a more natural viewing position, offering a compact and ergonomic solution for enhancing workspace comfort. Ideal for desks at home, in the office, or on the go. Elevate the screen closer to eye level for improved posture and viewing. The base features a 360° swivel mechanism, allowing effortless rotation of the entire stand for quick adjustments, screen sharing, or collaborative work without moving the stand. The tray tilts to help optimize viewing angles, the slide stops, and the rubber pads keep the device secure and help prevent cosmetic damage. Riser is made from aluminum with a space grey anodized finish, combining a sturdy build with a clean look. A vented platform promotes passive airflow to support stable device temperatures. At the same time, the space beneath can store a keyboard, mouse, or accessories. When collapsed, the riser measures approximately 8.4×10.2x3.1-inch (21.5x25.9x8cm), making it easy to transport and store.
StarTech.com - notebook stand - 360° rotating base
Notebook stand - 360° rotating base
Placing / Mounting
Desktop
Silver
Product Material
Aluminium
21.8 cm x 25.8 cm x 5.8 cm
942 g
360 degree swivel capability, tilt adjustment, passive airflow design, foldable, anti-slip pads
5-year warranty
Placing / Mounting
Desktop
Product Material
Aluminium
21.8 cm
25.8 cm
5.8 cm
Max Load Weight
5 kg
942 g
30 cm x 30 cm x 5.5 cm / 1 kg
Silver
Finish
Anodised
Limited warranty: - 5 years
