StarTech.com Rolling TV Cart/Portable Mount
Quicklinx: J1JNWS00 Mfr#: 1110C-MOBILE-TV-CART
11 In Stock
£429.22 ex VAT
£515.06 inc VAT
The StarTech.com Rolling TV Cart/Stand accommodates flat panel displays ranging from 60 to 100 inches, offering a versatile solution for various settings. This robust cart has a maximum load capacity of 220 lb and features an integrated cable management system to keep cables tidy and organized. With four wheels, it allows for easy movement between rooms or different event spaces. The adjustable height feature ensures precise positioning, and the tilt function provides optimal viewing angles, enhancing the experience for any audience.
Constructed from durable materials including aluminum and steel, this cart is lightweight yet sturdy. It includes all necessary assembly components, making the setup straightforward. With various flat panel mount interface options, this cart is compatible with a wide range of screens, increasing its usability in commercial or professional environments.
  • Versatile compatibility
    This cart supports various flat panel mount interfaces, including 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 200 mm, 300 x 300 mm, and 1000 x 600 mm, ensuring compatibility with numerous monitor types and sizes.
  • Robust construction
    Made from high-quality aluminum, steel, and plastic, the Rolling TV Cart is built to last, providing reliable support for larger screens while remaining lightweight for mobility.
  • Adjustable viewing angles
    The cart features a tilt range from -10° to 5°, allowing users to set their display for optimal visibility in any environment, enhancing the viewer experience.
  • Mobility with stability
    Equipped with four sturdy wheels, this cart allows for smooth movement and positioning while ensuring stability once in place, making it suitable for dynamic settings such as presentations or events.
  • Convenient assembly
    The product comes with all necessary assembly components, including screws and a hex key, simplifying setup and ensuring that users can quickly put it into service.
StarTech.com Rolling TV Cart/Stand On Wheels, Up to 100inch/220lb Screens cart - for flat panel - black, silver
Cart
75.5 cm x 120 cm x 240 cm
Tilt
-10° to 5°
Lift
45 cm
Adjustments
38.2 kg
Recommended Use
Flat panel
Recommended Display Size
60"-100"
VESA Mounting Interface
200 x 200 mm, 300 x 200 mm, 300 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 800 x 400 mm, 1000 x 600 mm
Max Load Weight
100 kg
Material
Plastic, aluminium, steel
Black, silver
Wheels Qty
4
Package Content
Base, left leg, right leg, left leg cover, right leg cover, universal plate, 2 universal plate end caps, 2 grab handles, 4 x casters, left column, right column, crank handle, right TV bracket, left TV bracket, 2 column top cover, camera shelf, 2 shelf brackets, camera shelf plate, connection bar, m5x40 screw, 4 x M6x25 screws, 5 x M4x6 screws, 4 x M6x14 screws, 12 x m8x25 screws, 12 x m6x8 screws, 4 x M5x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x M8x50 screws, 4 washers, 8 x spacers (small), 8 x spacers (large), hex key (5mm), wrench (19mm), 8 adhesive cable management clips
5-year warranty
75.5 cm
120 cm
240 cm
38.2 kg
Material
Black, silver
Package Content
AV Furniture
Cart
Recommended Use
Flat panel
Cable Management
Integrated cable management
60"-100"
Tilt
-10° to 5°
Lift
45 cm
Adjustments
Max Load Weight
100 kg
Wheels Qty
4
Assembly Required
Dimensions & Weight Details
120 cm x 56.5 cm x 22.5 cm / 41.6 kg
Limited warranty - 5 years
J1JN StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
J1JN StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £81.45
