The StarTech.com RJ45 Port Locks - 10 Pack with Security Key offers enhanced security and maintenance convenience for your networking infrastructure. These locking RJ45 port blockers are designed to fit securely into RJ-45 connectors, effectively preventing unauthorized access and tampering with your network setup. Constructed from high-quality polycarbonate, these port locks are durable and reusable, allowing for easy removal and reinsertion with the included security key. This feature is beneficial for IT professionals who require flexibility in managing and adjusting network configurations. Additionally, the port locks double as dust covers, providing an extra layer of protection against contaminants that can affect network performance. With a wide operating temperature range, these port locks are suitable for a variety of environments, from server rooms to switches and wall plates. Investing in the StarTech.com RJ45 Port Locks is a smart choice for ensuring the integrity and reliability of your network infrastructure.
Enhanced security
The RJ45 Port Locks from StarTech.com offer an effective solution to secure network ports and protect them from unauthorized access. With a specialized design that fits snugly into RJ-45 connectors, these port locks prevent tampering and ensure that your network configuration remains intact. -
Durable construction
Crafted from high-quality polycarbonate, these RJ45 Port Locks are built to withstand the rigors of daily use. The durable material ensures longevity and reliability, making it an ideal choice for busy server rooms, switches, and wall plates environments. -
Easy maintenance
Featuring a reusable design, these port locks can be easily removed and reinserted as needed, thanks to the included security key. This flexibility allows for hassle-free maintenance and adjustments to your network setup, while also serving as an effective dust cover to protect against contaminants.
- StarTech.com RJ45 Port Locks - 10 Pack with Security Key, Locking RJ45 Port Blocker/Dust Cover, Reusable Ethernet/LAN Port Protector, Snap In RJ45 Dust Blocker for Servers/Switches/Wall Plates - LAN port blocker with key
- Product Type
- Package Content
- 10 x port blockers, key
- 1 cm x 1.2 cm x 1 cm
- 4 g
- Product Material
- Polycarbonate
- White
- 2-year warranty
- Product Type
- Package Content
- Product Material
- Polycarbonate
- 1 cm
- 1.2 cm
- 1 cm
- 4 g
- Enclosure Colour
- White
- Compatible Connector Type
- RJ-45
- Dust cover, reusable
- Shipping Width
- 9 cm
- Shipping Depth
- 12.5 cm
- Shipping Height
- 1 cm
- Limited warranty - 2 years
- -10 °C
- 50 °C
- = 90%
StarTech.com White Cat 6 RJ45 Keystone Jack Network Coupler - F/F | In Stock | £8.27 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.00 |
StarTech.com Temperature/Humidity Meter | In Stock | £23.74 |
StarTech.com Handheld Sound Level Meter | In Stock | £22.93 |
