Connect two Cat 6 cables to extend a network connection using this RJ45 Inline Coupler. The female to female Ethernet coupler maintains optimal signal integrity while achieving low insertion loss that exceeds industry standards.
Wide Compatibility
The Cat6 Coupler facilitates 10Gbps, 1Gbps, and 10/100 speeds and is compatible with common networking standards including 10/100/1000BASE-T, and advanced protocols such as 2.5GBASE-T/5GBASE-T -
Durable Construction
The RJ45 Coupler features a durable polycarbonate housing and gold-plated phosphor bronze RJ45 contacts for dependable, long-lasting performance and reliability.
 - StarTech.com RJ45 Coupler, Inline Cat6 Coupler, Female to Female (F/F) T568 Connector, Unshielded Ethernet Cable Extension (IN-CAT6-COUPLER-U1) - network coupler - white
 - Network coupler - CAT 5/5e/6
- Technology
 - Unshielded
- Wiring Scheme
 - T568B
 - Passive adapter, polycarbonate housing, 750 mating cycles, phosphor bronze contacts
- Connector
 - RJ-45 - female
- Connector (Second End)
 - RJ-45 - female
 - White
 - Limited lifetime warranty
- Network Cable Type
- Technology
 - Unshielded
- Wiring Scheme
 - T568B
- Plated Connector
 - Gold
 - 1.5 cm
 - 3 cm
 - 1.7 cm
 - White
- Connector
 - RJ-45 - female
 - RJ-45 - female
 - Plug and Play, TIA/EIA-568-B, TIA-568-C.2
 - 0 °C
 - 70 °C
                        StarTech.com RJ45 RJ11 Crimp Tool with Cable Stripper | In Stock | £23.80 |
                        StarTech.com Professional Multi Function RJ45 RJ11 USB and BNC Cable Test | In Stock | £90.30 |
                        StarTech.com Shielded RJ45 Coupler, Cat6a | In Stock | £13.67 |
