StarTech.com RJ45 Cat6 Coupler, 5-Pack
Quicklinx: HKKVWS00 Mfr#: IN-CAT6-COUPLER-U5
Hurry, only 3 left in stock!
£34.22 ex VAT
£41.06 inc VAT
The RJ45 Coupler 5-Pack is a convenient solution for multiple installations. Connect two Cat 6 cables to extend a network connection. The female to female Ethernet coupler maintains optimal signal integrity while achieving low insertion loss that exceeds industry standards.
  • Wide Compatibility
    The Cat6 Coupler facilitates 10Gbps, 1Gbps, and 10/100 speeds and is compatible with common networking standards including 10/100/1000BASE-T, and advanced protocols such as 2.5GBASE-T/5GBASE-T
  • Durable Construction
    The RJ45 Coupler features a durable polycarbonate housing and gold-plated phosphor bronze RJ45 contacts for dependable, long-lasting performance and reliability.
StarTech.com RJ45 Coupler 5-Pack, Inline Cat6 Coupler, Female to Female (F/F) T568 Connector, Unshielded Ethernet Cable Extension - 5 Pack (IN-CAT6-COUPLER-U5) - network coupler - white
Network coupler - CAT 5/5e/6
Packaged Quantity
5 (specifications are for single item)
Unshielded
Wiring Scheme
T568B
Passive adapter, polycarbonate housing, 750 mating cycles, phosphor bronze contacts
Connector
RJ-45 - female
Connector (Second End)
RJ-45 - female
White
Packaged Quantity
Network Cable Type
Unshielded
Wiring Scheme
T568B
Plated Connector
Gold
1.5 cm
3 cm
1.7 cm
White
Connector
RJ-45 - female
RJ-45 - female
Plug and Play, TIA/EIA-568-B, TIA-568-C.2
70 °C
HKKV StarTech.com RJ45 RJ11 Crimp Tool with Cable Stripper In Stock £24.01
HKKV StarTech.com Shielded RJ45 Coupler, Cat6a In Stock £14.02
