StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F
Quicklinx: 6PDYWS00 Mfr#: GC1515MFRA2
Hurry, only 3 left in stock!
£7.03 ex VAT
£8.43 inc VAT
Add space for your VGA port and connect a VGA cable even in tight installation spaces. This Right Angle VGA to VGA Cable Adapter Type 2 provides one right angled VGA male connector and one standard VGA female connector - allowing you to connect the cable to a VGA female port, even if space around the VGA port is limited.
StarTech.com Right Angle VGA Adapter - Right Angle VGA to VGA - Male/Female - Type 2 - Male VGA to Female VGA (GC1515MFRA2) - VGA adapter
VGA adapter
90° connector
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
RoHS
Grey
P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM, MXT101MMHD15, MXT101MMHD6, MXT101MMHQ20, MXTHQMM10MA, MXTHQMM15A, MXTHQMM15MA, MXTHQMM25A, MXTHQMM2MA, MXTHQMM30A, MXTHQMM35A, MXTHQMM50A, MXTHQMM5MA
VGA adapter
90° connector
Grey
Connector
15 pin HD D-Sub (HD-15) - female
RoHS
