StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F
Quicklinx: 6PDWWS00 Mfr#: GC1515MFRA1
£6.85 ex VAT
£8.22 inc VAT
This Right Angle VGA to VGA Cable Adapter Type 1 provides one right angled VGA male connector and one standard VGA female connector - allowing you to connect the cable to a VGA female port, even if space around the VGA port is limited.
  • Flexible connectivity
    The right angle design of this VGA adapter allows for better cable management in tight spaces, reducing strain on the connectors and prolonging the lifespan of devices.
  • Reliable performance
    With 15 pin HD D-Sub (HD-15) connectors on each end, this adapter ensures stable and clear video signals between connected devices.
StarTech.com Right Angle VGA Adapter - Right Angle VGA to VGA - Male/Female - Type 1 - VGA Adapter Cable (GC1515MFRA1) - VGA adapter
VGA adapter
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
RoHS
Grey
P/N: MXT101MMHQ1, MXT101MMHQ30, MXT101MMHQ40, MXT101MMHQ45, MXT101MMHQ55, MXT101MMHQ60, MXTHQMM10MA, MXTHQMM15A, MXTHQMM15MA, MXTHQMM25A, MXTHQMM2MA, MXTHQMM30A, MXTHQMM35A, MXTHQMM50A, MXTHQMM5MA, MXTMMHQ10M, MXTMMHQ15M, MXTMMHQ20M, MXTMMHQ25M, MXTMMHQ2M, MXTMMHQ30M, MXTMMHQ3M, MXTMMHQ5M, MXTMMHQ7M
VGA adapter
Grey
Connector
15 pin HD D-Sub (HD-15) - female
RoHS
P/N: MXT101MMHD15, MXT101MMHD6, MXT101MMHQ1, MXT101MMHQ20, MXT101MMHQ30, MXT101MMHQ40, MXT101MMHQ45, MXT101MMHQ55, MXT101MMHQ60, MXTHQMM10MA, MXTHQMM15A, MXTHQMM15MA, MXTHQMM25A, MXTHQMM2MA, MXTHQMM30A, MXTHQMM35A, MXTHQMM50A, MXTHQMM5MA, MXTMMHQ10M, MXTMMHQ15M, MXTMMHQ20M, MXTMMHQ25M, MXTMMHQ2M, MXTMMHQ30M, MXTMMHQ3M, MXTMMHQ5M, MXTMMHQ7M
