This Right Angle VGA to VGA Cable Adapter Type 1 provides one right angled VGA male connector and one standard VGA female connector - allowing you to connect the cable to a VGA female port, even if space around the VGA port is limited.
Flexible connectivity
The right angle design of this VGA adapter allows for better cable management in tight spaces, reducing strain on the connectors and prolonging the lifespan of devices. -
Reliable performance
With 15 pin HD D-Sub (HD-15) connectors on each end, this adapter ensures stable and clear video signals between connected devices.
- StarTech.com Right Angle VGA Adapter - Right Angle VGA to VGA - Male/Female - Type 1 - VGA Adapter Cable (GC1515MFRA1) - VGA adapter
- VGA adapter
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- HD-15 (VGA) - female
- RoHS
- Grey
- Limited lifetime warranty
- Designed For
- P/N: MXT101MMHQ1, MXT101MMHQ30, MXT101MMHQ40, MXT101MMHQ45, MXT101MMHQ55, MXT101MMHQ60, MXTHQMM10MA, MXTHQMM15A, MXTHQMM15MA, MXTHQMM25A, MXTHQMM2MA, MXTHQMM30A, MXTHQMM35A, MXTHQMM50A, MXTHQMM5MA, MXTMMHQ10M, MXTMMHQ15M, MXTMMHQ20M, MXTMMHQ25M, MXTMMHQ2M, MXTMMHQ30M, MXTMMHQ3M, MXTMMHQ5M, MXTMMHQ7M
- VGA adapter
- Grey
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 15 pin HD D-Sub (HD-15) - female
- RoHS
- Designed For
- P/N: MXT101MMHD15, MXT101MMHD6, MXT101MMHQ1, MXT101MMHQ20, MXT101MMHQ30, MXT101MMHQ40, MXT101MMHQ45, MXT101MMHQ55, MXT101MMHQ60, MXTHQMM10MA, MXTHQMM15A, MXTHQMM15MA, MXTHQMM25A, MXTHQMM2MA, MXTHQMM30A, MXTHQMM35A, MXTHQMM50A, MXTHQMM5MA, MXTMMHQ10M, MXTMMHQ15M, MXTMMHQ20M, MXTMMHQ25M, MXTMMHQ2M, MXTMMHQ30M, MXTMMHQ3M, MXTMMHQ5M, MXTMMHQ7M
