StarTech.com Right Angle HDMI Adapter, M/F
Quicklinx: HSTLWS00 Mfr#: HDMI2HDMIMFRA
£4.75 ex VAT
£5.70 inc VAT
The StarTech.com Right Angle HDMI 2.0 Adapter is a versatile solution designed to enhance your home entertainment system. This 90-degree HDMI port saver is equipped with features that ensure high-quality audio and video output, including 4K60Hz support, HDR10, and 7.1 channel Surround Sound. Its durable construction, with a tear-resistant and wear-resistant PVC jacket, ensures a lifespan of 10,000 insertions, making it a reliable choice for those who frequently connect and disconnect their devices. The adapter's gold-plated connectors provide a stable and reliable connection, reducing the risk of signal loss. With its right-angled design, it's perfect for tight spaces, helping to prevent cable strain and port damage. Whether you're looking to connect your TV, gaming console, or any other HDMI-enabled device, this adapter offers the functionality and durability needed for a seamless entertainment experience.
  • Enhanced durability
    Designed with a tear-resistant and wear-resistant PVC jacket, this HDMI adapter ensures long-lasting performance with a lifespan of 10,000 insertions, making it a reliable choice for frequent use.
  • High-quality visuals and sound
    Supports 4K60Hz resolution, 10-bit deep color, and 7.1 channel Surround Sound, providing an immersive viewing experience with vibrant visuals and clear, high-quality audio. The 21:9 cinema aspect ratio enhances your movie-watching experience, bringing the theater into your living room.
  • Advanced connectivity features
    Featuring bidirectional functionality, this passive adapter supports HDR10 and Audio Return Channel (ARC), allowing for a seamless connection between your devices. With HDMI CEC support, you can easily control connected devices, making it a versatile addition to your home entertainment system.
StarTech.com Right Angle HDMI 2.0 Adapter, 90-Degree HDMI Port Saver, M/F - HDMI adapter
Cable
High Speed - HDMI adapter
Connector
HDMI - male
Connector (Second End)
HDMI - female - 90° right-angled
Passive adapter, bi-directional, 4K60Hz support
Cable Type
High Speed - HDMI adapter passive, bi-directional, 4K60Hz support
Jacket Material
PVC
Plated Connector
Gold
Recommended Use
TV
Audio Return Channel (ARC), HDMI CEC support (Consumer Electronics Control), HDR support, support HDR10, 3D ready, 32 audio channels, 10 bit deep colour, bus powered, tear-resistant, wear resistant, 21:9 cinema aspect ratio, 7.1 channel Surround Sound, bandwidth of 18 Gbps, 10000 insertions lifespan
Connector
19 pin HDMI Type A - male
19 pin HDMI Type A - female - 90° right-angled
WEEE, HDCP 2.2
2.9 cm
3.2 cm
1.2 cm
Shipping Width
9 cm
Shipping Depth
12.5 cm
Shipping Height
1 cm
Shipping Weight
17 g
Limited warranty - lifetime
