StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 2 - M/F
Quicklinx: 6PFBWS00 Mfr#: GC99MFRA2
£6.32 ex VAT
£7.58 inc VAT
This Right Angle DB9 to DB9 Serial Cable Adapter features one Right Angled DB9 Male serial connector and one standard DB9 female serial connector - a convenient solution for connecting serial devices where connection space around the DB9 port is limited.
Please note: there are two variations of this product, positioned differently to allow for easier connections based on the direction of right angle needed.
  • Versatile connectivity
    The Right Angle DB9 to DB9 Serial Cable Adapter Type 2 - M/F facilitates seamless connection between serial devices. Its unique right-angle design ensures an efficient use of space, making it ideal for setups with limited room.
  • Robust compatibility
    Designed to support PC compatibility, this adapter ensures a reliable connection between a wide range of devices, enhancing the versatility of your serial connections.
  • Quality assurance
    Adhering to RoHS compliant standards, this serial cable adapter underscores a commitment to environmental responsibility and user safety, while maintaining high performance.
StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 2 - M/F (GC99MFRA2) - serial adapter - DB-9 to DB-9
Serial adapter
90° connector
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Grey
P/N: ICUSB2324852, ICUSB232DB25, ICUSB232INT1, ICUSB232INT2, ICUSB422
Serial adapter
90° connector
Grey
Connector
RoHS
