StarTech.com's Replacement USB to PS/2 Mouse Adapter converts a USB-A (male) connector into a PS/2 (male) connector, allowing you to plug your USB mouse into a PS/2 port.
This high quality USB-PS/2 mouse adapter is designed as a replacement for a product that originally shipped with a USB to PS/2 converter.
This product is designed as a replacement adapter for a mouse that originally shipped with a USB-PS/2 adapter. If your product did not ship with an adapter, try StarTech.com's PS22USB instead.
Convenient connectivity
Easily connect USB mice to systems that require a PS/2 connection, ensuring compatibility with older technology. -
Robust design
Built with quality materials for a reliable connection that withstands repeated use and ensures performance over time.
- StarTech.com Replacement USB Mouse to PS/2 Adapter - F/M - USB mouse to PS2 Adapter - USB to PS2 Adapter - (GC46FM) - mouse adapter
- Mouse adapter
- Connector
- 6 pin mini-DIN (PS/2 style) - male
- Connector (Second End)
- 4 pin USB Type A - female
- Limited lifetime warranty
- Mouse adapter
- Connector
StarTech.com Replacement USB Keyboard to PS/2 Adapter - F/M | In Stock | £6.15 |
