Connect a PS/2 compatible USB Keyboard to a computer through a PS/2 port. The GC46FMKEY USB Keyboard to PS/2 Adapter features a USB-A female connector and a 6-Din (PS/2) male port, allowing you to connect a USB keyboard to a computer through a PS/2 port.
Please Note: This product is designed as a replacement adapter for keyboards that originally shipped with a USB-PS / 2 adapter. If your product did not ship with an adapter, try StarTech.com 's PS22USB instead.
Reliable connectivity
The adapter allows for seamless communication between USB keyboards and older PS/2 systems, ensuring you can use your preferred keyboard with a variety of setups. -
Versatile design
With its 4-pin USB Type-A female and 6-pin mini-DIN male connectors, this adapter meets diverse connectivity needs and maintains compatibility across different systems. -
Convenient Plug-and-Play
This adapter requires no additional drivers or software and offers a straightforward way to connect USB keyboards to devices equipped with a PS/2 port. -
Durable materials
Constructed with high-quality components, the adapter is designed for longevity and robustness, making it suitable for everyday use and long-term applications. -
Backed by a limited lifetime warranty, the adapter provides assurance of its reliability and performance, supporting users as they navigate their connection needs.
- StarTech.com Replacement USB Keyboard to PS/2 Adapter - F/M - USB keyboard to PS2 Adapter - USB to PS2 Adapter (GC46FMKEY) - keyboard adapter
- Keyboard adapter
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 6 pin mini-DIN (PS/2 style) - male
- Limited lifetime warranty
- Keyboard adapter
- Connector
StarTech.com Replacement PS/2 Mouse to USB Adapter - F/M | In Stock | £3.49 |
StarTech.com Replacement PS/2 Keyboard to USB Adapter - F/M | In Stock | £6.06 |
StarTech.com Replacement USB Mouse to PS/2 Adapter – F/M | In Stock | £6.15 |
Customer reviews
Write a review for the StarTech.com Replacement USB Keyboard to PS/2 Adapter - F/M here!
Beware
Reviewed by Anonymous Review Posted 02/11/2007
This item is inadequately described. The rating is meaningless as the device did not work as initially hoped. The product is designed as a replacement adapter for keyboards that originally shipped with a PS/2 to USB converter. If your product did not ship with a converter, StarTech suggest trying a USBPS2PC instead. (Dabs Quicklinx : 404LWS, which did work for me).
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
