StarTech.com Replacement USB Keyboard to PS/2 Adapter - F/M
Customer rating: 3.0* (Write a review)
Quicklinx: 4JR4WS00 Mfr#: GC46FMKEY
10 In Stock
£5.79 ex VAT
£6.94 inc VAT
Connect a PS/2 compatible USB Keyboard to a computer through a PS/2 port. The GC46FMKEY USB Keyboard to PS/2 Adapter features a USB-A female connector and a 6-Din (PS/2) male port, allowing you to connect a USB keyboard to a computer through a PS/2 port.
Please Note: This product is designed as a replacement adapter for keyboards that originally shipped with a USB-PS / 2 adapter. If your product did not ship with an adapter, try StarTech.com 's PS22USB instead.
  • Reliable connectivity
    The adapter allows for seamless communication between USB keyboards and older PS/2 systems, ensuring you can use your preferred keyboard with a variety of setups.
  • Versatile design
    With its 4-pin USB Type-A female and 6-pin mini-DIN male connectors, this adapter meets diverse connectivity needs and maintains compatibility across different systems.
  • Convenient Plug-and-Play
    This adapter requires no additional drivers or software and offers a straightforward way to connect USB keyboards to devices equipped with a PS/2 port.
  • Durable materials
    Constructed with high-quality components, the adapter is designed for longevity and robustness, making it suitable for everyday use and long-term applications.
  • Limited lifetime warranty
    Backed by a limited lifetime warranty, the adapter provides assurance of its reliability and performance, supporting users as they navigate their connection needs.
StarTech.com Replacement USB Keyboard to PS/2 Adapter - F/M - USB keyboard to PS2 Adapter - USB to PS2 Adapter (GC46FMKEY) - keyboard adapter
Keyboard adapter
Connector
4 pin USB Type A - female
Connector (Second End)
6 pin mini-DIN (PS/2 style) - male
Keyboard adapter
Connector
4JR4 StarTech.com Replacement PS/2 Mouse to USB Adapter - F/M In Stock £4.83
4JR4 StarTech.com Replacement PS/2 Keyboard to USB Adapter - F/M In Stock £5.78
4JR4 StarTech.com Replacement USB Mouse to PS/2 Adapter – F/M In Stock £5.79
Customer reviews
Write a review for the StarTech.com Replacement USB Keyboard to PS/2 Adapter - F/M here!
Beware
Reviewed by Anonymous Review Posted 02/11/2007
This item is inadequately described. The rating is meaningless as the device did not work as initially hoped. The product is designed as a replacement adapter for keyboards that originally shipped with a PS/2 to USB converter. If your product did not ship with a converter, StarTech suggest trying a USBPS2PC instead. (Dabs Quicklinx : 404LWS, which did work for me).
  • Overall 3*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
