StarTech.com Replacement PC Mounting #6-32 to M3 Metal Jack Screw Standoff 50 Pack
Quicklinx: 404DWS00 Mfr#: SCREWNUTM
Type: Screw
13 In Stock
£6.88 ex VAT
£8.25 inc VAT
Ace Techman knows how frustrating it can be when assembling a system that functions at its optimal performance when what you need are a few small parts like screws or nuts. StarTech.com carries all parts, big or small. This product acts as a screwmount for your workstation's motherboard.
  • Durable material
    Constructed from high-quality metal, these jackscrew standoffs are built to withstand demanding conditions while maintaining structural integrity.
  • Generous pack size
    The pack of 50 standoffs provides an ample supply for various projects, ensuring there are enough components available for extensive use.
StarTech.com Metal Jackscrew Standoffs #6-32 - Jackscrew standoff - 0.2 in (pack of 50) - SCREWNUTM - jackscrew standoff
Jackscrew standoff
Packaged Quantity
50 (specifications are for single item)
Product Material
Metal
Length
0.4 cm
1-year warranty
P/N: PCSCREWKIT
Packaged Quantity
Jackscrew standoff
Product Material
Metal
Length
0.4 cm
Limited warranty: - 1 year
P/N: PCSCREWKIT
Type: Screw
