Ace Techman knows how frustrating it can be when assembling a system that functions at its optimal performance when what you need are a few small parts like screws or nuts. StarTech.com carries all parts, big or small. This product acts as a screwmount for your workstation's motherboard.
Durable material
Constructed from high-quality metal, these jackscrew standoffs are built to withstand demanding conditions while maintaining structural integrity. -
Generous pack size
The pack of 50 standoffs provides an ample supply for various projects, ensuring there are enough components available for extensive use.
- StarTech.com Metal Jackscrew Standoffs #6-32 - Jackscrew standoff - 0.2 in (pack of 50) - SCREWNUTM - jackscrew standoff
- Product Type
- Packaged Quantity
- 50 (specifications are for single item)
- Product Material
- Metal
- Length
- 0.4 cm
- 1-year warranty
- Designed For
- P/N: PCSCREWKIT
- Packaged Quantity
- Product Type
- Product Material
- Metal
- Length
- 0.4 cm
- Limited warranty: - 1 year
- Designed For
- P/N: PCSCREWKIT
