Product
StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan
Reduced Price - Whilst Stocks Last!
Quicklinx: 6BF3WS00 Mfr#: FAN7X10TX3
Type: CPU Cooler
Stock Status: Clearance
Hurry, only 1 left in stock!
£3.21 ex VAT
£3.85 inc VAT
Express delivery Order within the next 21 hours for delivery on Tuesday
This 70mm TX3 Dual Ball Bearing CPU Cooler Fan is a cost-effective replacement fan for standard CPUs as well as many different types of 1U or low profile CPU coolers that use a 70mm fan.
For peace of mind, the CPU cooling fan features a Tachometer pin on the TX3 motherboard connector that provides the host system with fan operating status, while a dual ball bearing design helps provide smooth operation and longer (fan) lifespan.
StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan - case fan
Case fan
Fan Diameter
70 mm
Fan Height
10 mm
Fan Bearing
Dual ball bearing
Rotation Speed
3500 rpm
Air Flow
21.3 cfm
Power Connector
3-pin plug
Product Material
Plastic
Fan speed monitoring
2 years warranty
Case fan
Product Material
Plastic
Heatsink & Fan
Fan Diameter
70 mm
Fan Height
10 mm
Fan Bearing
Dual ball bearing
Rotation Speed
3500 rpm
Air Flow
21.3 cfm
Power Connector
3-pin plug
UL, RoHS
Sound Emission
33 dB
6BF3 StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable In Stock £2.76
Type: CPU Cooler
Price Range Ex VAT: 0 - 50
