This 70mm TX3 Dual Ball Bearing CPU Cooler Fan is a cost-effective replacement fan for standard CPUs as well as many different types of 1U or low profile CPU coolers that use a 70mm fan.
For peace of mind, the CPU cooling fan features a Tachometer pin on the TX3 motherboard connector that provides the host system with fan operating status, while a dual ball bearing design helps provide smooth operation and longer (fan) lifespan.
 - StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan - 3 pin case Fan - TX3 Fan - 70mm Fan (FAN7X10TX3) - case fan
- Product Type
 - Case fan
 - Black
- Fan Diameter
 - 70 mm
- Fan Height
 - 10 mm
- Fan Bearing
 - Dual ball bearing
- Rotation Speed
 - 3500 rpm
- Air Flow
 - 21.3 cfm
- Power Connector
 - 3-pin plug
- Product Material
 - Plastic
 - Fan speed monitoring
 - 2-year warranty
- Product Type
 - Case fan
- Product Material
 - Plastic
 - Black
Heatsink & Fan
- Fan Diameter
 - 70 mm
- Fan Height
 - 10 mm
- Fan Bearing
 - Dual ball bearing
- Rotation Speed
 - 3500 rpm
- Air Flow
 - 21.3 cfm
- Power Connector
 - 3-pin plug
 - UL, RoHS
 - Limited warranty: - 2 years
- Sound Emission
 - 33 dB
