StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan
Quicklinx: 6BF3WS00 Mfr#: FAN7X10TX3
Type: CPU Cooler
7 In Stock
£5.50 ex VAT
£6.60 inc VAT
Standard delivery Delivered within 3-5 working days
This 70mm TX3 Dual Ball Bearing CPU Cooler Fan is a cost-effective replacement fan for standard CPUs as well as many different types of 1U or low profile CPU coolers that use a 70mm fan.
For peace of mind, the CPU cooling fan features a Tachometer pin on the TX3 motherboard connector that provides the host system with fan operating status, while a dual ball bearing design helps provide smooth operation and longer (fan) lifespan.
StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan - 3 pin case Fan - TX3 Fan - 70mm Fan (FAN7X10TX3) - case fan
Case fan
Fan Diameter
70 mm
Fan Height
10 mm
Fan Bearing
Dual ball bearing
Rotation Speed
3500 rpm
Air Flow
21.3 cfm
Power Connector
3-pin plug
Product Material
Plastic
Fan speed monitoring
Case fan
Product Material
Plastic
Heatsink & Fan
Fan Diameter
70 mm
Fan Height
10 mm
Fan Bearing
Dual ball bearing
Rotation Speed
3500 rpm
Air Flow
21.3 cfm
Power Connector
3-pin plug
UL, RoHS
Limited warranty: - 2 years
Sound Emission
33 dB
6BF3 StarTech.com 70x15mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.30
Type: CPU Cooler
