Add a second power supply to your media chassis to connect a redundant power supply for uninterrupted operation.
Continuous, Reliable Power
The redundant power supply unit delivers 130W AC to maintain uninterrupted operation across all fifteen media converter slots. It is ideal for enterprise, ISP, and metro networks where continuous uptime and stable performance are essential.
Hot-Swappable Redundancy
The unit installs easily into the redundant power bay of the MCM15-MEDIA-CHASSIS, providing automatic failover protection during replacement or failure. Hot-swappable design enables true zero-downtime power management for mission-critical systems.
Universal Input and Fanless Efficiency
Supporting 100-240V AC input, the power supply offers global compatibility with plug-and-play, tool-free installation. Fanless cooling uses chassis airflow for quiet, reliable operation across a wide temperature range.
TAA-Compliant and Built for Longevity
Fully TAA-compliant and engineered for durability, the power supply ensures dependable performance for high-density fiber and media-conversion systems in data centers, metro backbones, and other critical networks.
StarTech.com Redundant Power Supply Unit
