StarTech.com Receiver for ST12MHDLNHK
Quicklinx: F2GMWS00 Mfr#: ST12MHDLNHR
£154.49 ex VAT
£185.38 inc VAT
Broadcast your HDMI signal to multiple locations throughout your site, using your existing network infrastructure. The HDMI over IP receiver works with the HDMI over IP Extender (ST12MHDLNHK) to distribute HDMI to an additional remote display. You can add multiple receivers (each sold separately) to easily distribute HDMI to multiple locations.
With additional receivers, you can scale your HDMI over IP kit installation to suit your needs. In a point-to-multipoint setup, you can route HDMI over IP to as many receivers as you need. For additional scalability, you can combine up to 99 different kits (ST12MHDLNHK) to create a multipoint-to-multipoint setup, where you can route different HDMI source signals to different displays. Mounting hardware and IR extenders are included for each transmitter and receiver to ensure tidy, professional installation and hassle-free remote operation.
The receiver maintains your HD video signal, supporting resolutions up to 1080p. Maintaining your HD quality over IP makes it easy to distribute dynamic digital signage throughout your site to attract and engage customers.
Unlike some video-over-IP solutions that consume your bandwidth, this HDMI over IP solution uses video compression to distribute high-quality HDMI over your local area network, with minimal bandwidth requirements. Extending your HDMI using compression saves your network resources, avoiding the hassle of a separate video network.
StarTech.com HDMI over IP Receiver for ST12MHDLNHK - Video over IP - HDMI over IP Extender - 1080p (ST12MHDLNHR) - video/audio/infrared extender - HDMI
Video/audio/infrared extender (receiver)
External
Australia, New Zealand, North America, United Kingdom, Europe
HDMI
P/N: ST12MHDLNHK
External
Wired
HDMI
1080p resolution support
1 x HDMI (output) - 19 pin HDMI Type A female , 1 x network - RJ-45 female , 1 x IR (input) , 1 x RS-232
IR receiver, rubber feet, mounting brackets, screwdriver, IR remote
1 x network cable , 1 x mini-USB type B to USB type A power cable , 1 x DB-9 to 2.5 mm serial adapter cable
Mounting Kit
Included
External power adapter
P/N: ST12MHDLNHK
F2GM StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
F2GM StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
F2GM StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.56
F2GM StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
F2GM StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.94
F2GM StarTech.com HDMI Over IP Extender Kit - 4K In Stock £464.90
