StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor
Quicklinx: F2GJWS00 Mfr#: RKCONS1708K
Type: KVM switch
Connectivity: USB
Ports: 8
Hurry, only 2 left in stock!
£974.99 ex VAT
£1,169.98 inc VAT
Providing centralized control of up to eight servers, this 8-port rackmount KVM console gives you easy access to your systems. With a minimal footprint, it mounts in a server rack or cabinet using only 1U of rack space.
The 1U rackmount console features a built-in keyboard, a touchpad for intuitive control, and a 17-inch LCD display that supports resolutions up to 1280x1024.
This 8-port KVM console comes with everything you need to set up right out of the box: 8 VGA KVM Cables; Mounting Rails; M5 Cage Nuts and Screws.
With direct access to eight systems or servers, the 8-port KVM module gives you the flexibility you need to easily integrate the console into your existing server infrastructure.
Rack consoles provide convenient, rack-mounted control options for single servers or the entire server room. KVM consoles include LCD display, keyboard, and trackpad, all sliding into 1U of rack space.
  • High-resolution display
    The KVM console features a 17-inch LCD monitor with a native resolution of 1280 x 1024, providing clear visuals for monitoring server activities.
  • Robust connectivity options
    With support for USB and VGA connections, this console ensures compatibility with a variety of devices, simplifying management tasks.
  • Reliable performance
    Built to last, the console has a mean time between failures (MTBF) of 50,000 hours, ensuring dependable operation and reducing downtime.
  • Spacious design
    The 1U rack-mountable design optimizes space in server racks, allowing for efficient use of valuable real estate while providing easy access.
  • Excellent viewing angles
    Featuring a horizontal viewing angle of 170 degrees and a vertical viewing angle of 160 degrees, the console offers flexibility in viewing from various positions.
StarTech.com 8 Port Rackmount KVM Console with 6ft Cables, Integrated KVM Switch with 17" LCD Monitor, Fully Featured 1U LCD KVM Drawer- OSD KVM, Durable 50,000 MTBF, USB + VGA Support - 17in. LCD KVM Drawer (RKCONS1708K) - KVM console - 17"
KVM console - 17"
KVM Switch
USB - 8 ports
Keyboard, touchpad, 8 port KVM switch
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
VGA
Voltage
AC 120/230 V
44.8 cm x 52.56 cm x 4.25 cm
Height (Rack Units)
1U
13.3 kg
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Display Type
KVM console / TFT active matrix
Diagonal Size
17"
Built-in Devices
8 port KVM switch
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Height (Rack Units)
1U
13.3 kg
Input
Keyboard, touchpad
KVM
KVM switch - 8 ports
Keyboard / Mouse Interface
USB
Max Resolution
1280 x 1024 @ 60 Hz
8 x VGA , 2 x USB 2.0 (Type A) , 2 x PS/2 , VGA output , Daisy chain port (HD-15)
8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
8 x keyboard / mouse / video cable - 1.83 m
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
Input Voltage
AC 120/230 V
Power Consumption (Typical)
13 Watt
Shipping Weight
19 kg
10 - 80% (non-condensing)
F2GJ StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
F2GJ StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.20
F2GJ StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.24
F2GJ StarTech.com 19in Cable Management Panel In Stock £23.58
F2GJ StarTech.com 8 Port KVM Console for Server Rack - 19in In Stock £1,134.60
F2GJ StarTech.com Single Server KVM Console for Server Rack -19" In Stock £730.86
F2GJ StarTech.com 16 port KVM VGA Console with KVM Switch - 19" In Stock £1,288.35
F2GJ StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p In Stock £904.75
F2GJ StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor In Stock £974.99
F2GJ StarTech.com 1U HD Single Server KVM In Stock £783.87
F2GJ StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles In Stock £39.35
F2GJ StarTech.com 6 ft. (1.8 m) USB KVM Cable for Rackmount Consoles In Stock £17.16
Type: KVM switch
Connectivity: USB
Ports: 8
Price Range Ex VAT: £750 - £1000
