Providing centralized control of up to eight servers, this 8-port rackmount KVM console gives you easy access to your systems. With a minimal footprint, it mounts in a server rack or cabinet using only 1U of rack space.
The 1U rackmount console features a built-in keyboard, a touchpad for intuitive control, and a 17-inch LCD display that supports resolutions up to 1280x1024.
This 8-port KVM console comes with everything you need to set up right out of the box: 8 VGA KVM Cables; Mounting Rails; M5 Cage Nuts and Screws.
With direct access to eight systems or servers, the 8-port KVM module gives you the flexibility you need to easily integrate the console into your existing server infrastructure.
Rack consoles provide convenient, rack-mounted control options for single servers or the entire server room. KVM consoles include LCD display, keyboard, and trackpad, all sliding into 1U of rack space.
High-resolution display
The KVM console features a 17-inch LCD monitor with a native resolution of 1280 x 1024, providing clear visuals for monitoring server activities. -
Robust connectivity options
With support for USB and VGA connections, this console ensures compatibility with a variety of devices, simplifying management tasks. -
Reliable performance
Built to last, the console has a mean time between failures (MTBF) of 50,000 hours, ensuring dependable operation and reducing downtime. -
Spacious design
The 1U rack-mountable design optimizes space in server racks, allowing for efficient use of valuable real estate while providing easy access. -
Excellent viewing angles
Featuring a horizontal viewing angle of 170 degrees and a vertical viewing angle of 160 degrees, the console offers flexibility in viewing from various positions.
- StarTech.com 8 Port Rackmount KVM Console with 6ft Cables, Integrated KVM Switch with 17" LCD Monitor, Fully Featured 1U LCD KVM Drawer- OSD KVM, Durable 50,000 MTBF, USB + VGA Support - 17in. LCD KVM Drawer (RKCONS1708K) - KVM console - 17"
- KVM console - 17"
- KVM Switch
- USB - 8 ports
- Keyboard, touchpad, 8 port KVM switch
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Voltage
- AC 120/230 V
- Black
- 44.8 cm x 52.56 cm x 4.25 cm
- Height (Rack Units)
- 1U
- 13.3 kg
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- 2-year warranty
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 17"
- Built-in Devices
- 8 port KVM switch
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Black
- 1U
- 13.3 kg
Input
KVM
- KVM switch - 8 ports
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1280 x 1024 @ 60 Hz
- 8 x VGA , 2 x USB 2.0 (Type A) , 2 x PS/2 , VGA output , Daisy chain port (HD-15)
- Included Accessories
- 8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
- Cables Included
- 8 x keyboard / mouse / video cable - 1.83 m
- Rack Mounting Kit
- Included
- MTBF
- 50,000 hour(s)
- Localisation
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 13 Watt
- Shipping Weight
- 19 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.45 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £39.94 |
StarTech.com 19in Cable Management Panel | In Stock | £23.30 |
StarTech.com 8 Port KVM Console for Server Rack - 19in | In Stock | £1,187.53 |
StarTech.com Single Server KVM Console for Server Rack -19" | In Stock | £750.49 |
StarTech.com 16 port KVM VGA Console with KVM Switch - 19" | In Stock | £1,303.52 |
StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p | In Stock | £942.18 |
StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor | In Stock | £1,019.51 |
StarTech.com 1U HD Single Server KVM | In Stock | £811.82 |
StarTech.com 10 ft. (3 m) USB KVM Cable for Rackmount Consoles | In Stock | £30.70 |
StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles | In Stock | £41.14 |
StarTech.com 6 ft. (1.8 m) USB KVM Cable for Rackmount Consoles | In Stock | £17.91 |
