StarTech.com Rack Cable Management D-Ring
Quicklinx: HQ1MWS00 Mfr#: CMHOOK1UN5PK
10 In Stock
£14.86 ex VAT
£17.83 inc VAT
Install this set of five 1U vertical cable management hooks internally/externally along the posts of a standard 19" 2/4-post server rack, to organize power and network cables.
  • Enhance cable management
    The cable D-ring organizer features a 0.4" (11 mm) opening to effortlessly insert bundled cables. Install multiple cable rings along the rack posts to improve airflow and minimize the port and connector strain.
  • Optimized cable routing
    Prevent sharp cable bends at connector ends and reduce port/connector stress by routing the cables through these hooks.
  • Wide compatibility
    This cable guide for racks and cabinets is constructed of steel and is compatible with any rack post that features 1U standard rack spacing. The powder-coated finish ensures durability, and the smooth surface prevents snagging and maintains cable integrity.
StarTech.com 5-Pack 1U Vertical Cable Management D-Ring Hooks, Cable Manager For 19" Server Racks/Cabinets, Network Rack Wire Organizers, Cable Guide Rings - cable management ring (vertical) - 1U
Cable management ring (vertical)
Packaged Quantity
5 (specifications are for single item)
Height (Rack Units)
1U
Product Material
Steel
4.5 cm x 10.1 cm x 4.5 cm
73 g
Type D-ring
Packaged Quantity
Product Material
Steel
Height (Rack Units)
1U
4.5 cm
10.1 cm
4.5 cm
73 g
24 cm x 17 cm x 4.5 cm / 448 g
Type D-ring
EIA RS-310-D
Limited warranty: - 2 years
HQ1M StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
HQ1M StarTech.com 50 Pkg M6 Cage Nuts In Stock £19.69
HQ1M StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.03
HQ1M StarTech.com M6 Rack Screws and Cage Nuts In Stock £15.09
