StarTech.com Quad Monitor USB-C Dock 4K60
Quicklinx: GW3WWS00 Mfr#: DK31C4DPPDUE
Device Type: Macbook, Chromebook, Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black, Space grey
£165.40 ex VAT
£198.48 inc VAT
This USB-C Gen 2 10Gbps docking station turns your USB-C or Thunderbolt 3 MacBook Pro, Windows laptop, and Chromebook into a powerful workstation. A USB 3.2 Gen 2 Type-C dock features everything you need, from quad HDMI or DisplayPort video outputs up to 4K 60 Hz to 10Gbps USB-C & USB-A downstream peripheral ports to 100W Power Delivery.
  • HDMI & DisplayPort for Four Monitor Outputs
    This USB-C Gen 2 docking station with DP 1.2 and HDMI 2.0 HDR support, is a perfect choice for dual, triple, or quad monitor setup, supporting up to quad 4K 60Hz display output, with any combination of four DisplayPort or HDMI video interfaces, on USB-C Gen 2 laptops, MacBooks (including M1 based systems) and Windows-based Thunderbolt 3 laptops. Display & Resolution Specs:
  • Power & Charge with 100W Power Delivery
    Power and charge USB-C/Thunderbolt 3 workstation laptops & ultrabooks with 100 watt PD. Higher power delivery, more than other USB-C 10Gbps quad monitor docks. Charge smartphones and other high powered devices with two downstream front-facing charging ports with BC 1.2 for USB-A and USB-C devices. Fast-charge ports support always-on charging so devices will charge whether or not a host laptop is connected.
  • Plenty of Downstream USB Ports
    This USB-C Gen 2 docking station features 4 downstream USB ports in total to connect USB peripherals. • 1x USB-C 3.2 Gen 2 (10 Gbps | 15W/3A) • 1x USB-A 3.2 Gen 1 (5 Gbps | 7.5W/1.5A) • 2x USB-A 3.2 Gen 1 (5 Gbps | 4.5W/0.9A) Also included, is a gigabit Ethernet port with PXE Boot and WoL support, as well as 4-position TRRS stereo audio headset/mic port.
  • Additional Security Features
    This USB-C docking station comes with plenty of security features a K-slot for a Kensington style laptop lock and holes to mount the dock on the desk or wall and includes a USB-IF Certified 1m USB-C cable.
  • Extra Ventilation
    USB-C dock features optimized ventilation on both ends and bottom side of dock to provide cooling support to higher temperature thermals that can be generated by high performance video/graphics applications and multiple 4K 60Hz video outputs.
StarTech.com USB-C Dock, 4K 60Hz Quad Monitor DisplayPort & HDMI, Universal USB C Docking Station with 100W Power Delivery Charging, USB Hub w/ 1x USB Type-C & 3x USB-A, Ethernet, Audio - Thunderbolt 3 Compatible (DK31C4DPPDUE) - docking station - USB-C 3.2 Gen 2 / Thunderbolt 3 - 4 x DP, 4 x HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
4 x DP, 4 x HDMI
9 cm x 21.5 cm x 4.65 cm
330 g
Black, space grey
United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 110-240 V
3-year warranty
Docking station
9 cm
21.5 cm
4.65 cm
330 g
Enclosure Colour
Black, space grey
Video
Max Resolution Details
5120 x 2880 (Dual Display (DisplayPort 1.2)) , 3840 x 2160 - 60 Hz (Quad Display)
4 x display / video - DisplayPort output - 20 pin DisplayPort , 4 x display / video - HDMI output - 19 pin HDMI Type A , 1 x audio - headphones/microphone - mini-phone 3.5 mm 4-pole , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB-C 3.2 Gen 2 with Power Delivery (100 W) - 24 pin USB-C , 2 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C cable - external - 1 m
Security lock slot (cable lock sold separately), wake on LAN, Preboot Execution Environment (PXE) support, 100W power delivery
Security Slot Type
Kensington security slot
USB-IF, DisplayLink Plug and Display, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.2, USB Power Delivery
Power adapter
AC 110-240 V
Apple macOS 10.14 or later, Google Chrome OS 61 or later, Microsoft Windows 10 / 11
Limited warranty - 3 years
Shipping Width
14.2 cm
Shipping Depth
23.1 cm
Shipping Height
9.7 cm
Shipping Weight
360 g
50 °C
GW3W StarTech.com Quad Monitor Stand - Steel In Stock £198.08
GW3W StarTech.com Desk Mount Quad Monitor Arm In Stock £178.72
GW3W StarTech.com Quad-Monitor Stand - For up to 32" VESA Mount Monitors In Stock £210.79
GW3W StarTech.com Quad Monitor Mount - Premium - For up to 27" VESA Monitors In Stock £402.59
Device Type: Chromebook
Device Type: Laptop
Colour: Black
Colour: Space grey
