This USB-C Gen 2 10Gbps docking station turns your USB-C or Thunderbolt 3 MacBook Pro, Windows laptop, and Chromebook into a powerful workstation. A USB 3.2 Gen 2 Type-C dock features everything you need, from quad HDMI or DisplayPort video outputs up to 4K 60 Hz to 10Gbps USB-C & USB-A downstream peripheral ports to 100W Power Delivery.
HDMI & DisplayPort for Four Monitor Outputs
This USB-C Gen 2 docking station with DP 1.2 and HDMI 2.0 HDR support, is a perfect choice for dual, triple, or quad monitor setup, supporting up to quad 4K 60Hz display output, with any combination of four DisplayPort or HDMI video interfaces, on USB-C Gen 2 laptops, MacBooks (including M1 based systems) and Windows-based Thunderbolt 3 laptops. Display & Resolution Specs: -
Power & Charge with 100W Power Delivery
Power and charge USB-C/Thunderbolt 3 workstation laptops & ultrabooks with 100 watt PD. Higher power delivery, more than other USB-C 10Gbps quad monitor docks. Charge smartphones and other high powered devices with two downstream front-facing charging ports with BC 1.2 for USB-A and USB-C devices. Fast-charge ports support always-on charging so devices will charge whether or not a host laptop is connected. -
Plenty of Downstream USB Ports
This USB-C Gen 2 docking station features 4 downstream USB ports in total to connect USB peripherals. • 1x USB-C 3.2 Gen 2 (10 Gbps | 15W/3A) • 1x USB-A 3.2 Gen 1 (5 Gbps | 7.5W/1.5A) • 2x USB-A 3.2 Gen 1 (5 Gbps | 4.5W/0.9A) Also included, is a gigabit Ethernet port with PXE Boot and WoL support, as well as 4-position TRRS stereo audio headset/mic port. -
Additional Security Features
This USB-C docking station comes with plenty of security features a K-slot for a Kensington style laptop lock and holes to mount the dock on the desk or wall and includes a USB-IF Certified 1m USB-C cable. -
Extra Ventilation
USB-C dock features optimized ventilation on both ends and bottom side of dock to provide cooling support to higher temperature thermals that can be generated by high performance video/graphics applications and multiple 4K 60Hz video outputs.
- StarTech.com USB-C Dock, 4K 60Hz Quad Monitor DisplayPort & HDMI, Universal USB C Docking Station with 100W Power Delivery Charging, USB Hub w/ 1x USB Type-C & 3x USB-A, Ethernet, Audio - Thunderbolt 3 Compatible (DK31C4DPPDUE) - docking station - USB-C 3.2 Gen 2 / Thunderbolt 3 - 4 x DP, 4 x HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- 4 x DP, 4 x HDMI
- 9 cm x 21.5 cm x 4.65 cm
- 330 g
- Black, space grey
- Localisation
- United Kingdom, Europe
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 110-240 V
- 3-year warranty
- Product Type
- Docking station
- 9 cm
- 21.5 cm
- 4.65 cm
- 330 g
- Enclosure Colour
- Black, space grey
- Localisation
Video
- Max Resolution Details
- 5120 x 2880 (Dual Display (DisplayPort 1.2)) , 3840 x 2160 - 60 Hz (Quad Display)
- Data Link Protocol
- 4 x display / video - DisplayPort output - 20 pin DisplayPort , 4 x display / video - HDMI output - 19 pin HDMI Type A , 1 x audio - headphones/microphone - mini-phone 3.5 mm 4-pole , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB-C 3.2 Gen 2 with Power Delivery (100 W) - 24 pin USB-C , 2 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Cables Included
- 1 x USB-C cable - external - 1 m
- Security lock slot (cable lock sold separately), wake on LAN, Preboot Execution Environment (PXE) support, 100W power delivery
- Security Slot Type
- Kensington security slot
- USB-IF, DisplayLink Plug and Display, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.2, USB Power Delivery
- Power Device
- Power adapter
- Voltage Required
- AC 110-240 V
- OS Required
- Apple macOS 10.14 or later, Google Chrome OS 61 or later, Microsoft Windows 10 / 11
- Limited warranty - 3 years
- Shipping Width
- 14.2 cm
- Shipping Depth
- 23.1 cm
- Shipping Height
- 9.7 cm
- Shipping Weight
- 360 g
- 0 °C
- 50 °C
StarTech.com Quad Monitor Stand - Steel | In Stock | £188.41 |
StarTech.com Desk Mount Quad Monitor Arm | In Stock | £171.25 |
