StarTech.com Quad Monitor Stand - Steel
Quicklinx: CRXYBTBS Mfr#: ARMBARQUAD
Accessory Type: Stand
£193.12 ex VAT
£231.74 inc VAT
Increase productivity and free up space by mounting four monitors to this attractive desktop stand. This free-standing quad-monitor stand saves you valuable desk space and boosts productivity, by creating a more comfortable and ergonomic workspace. Constructed of steel and aluminum, the robust monitor stand suspends up to four monitors above your desk or other work surface.
Clear up your desk surface and enjoy an ergonomic workspace. This computer monitor stand supports four displays that are each 13" to 27" (330 to 686 mm) in size and up to 17.6 lb. (8 kg) in weight.
With its dual-crossbar design, this monitor stand lets you mount four monitors onto a single base that rests on your desktop. This gives you more surface area on your desk for personal devices or for physical tasks like reviewing paper documents. And, adding extra monitors gives you ample screen space to simplify multitasking - using four displays makes it easier to reference material on several screens while working on another, saving you the time and hassle of having to flip back and forth between documents.
The monitor stand enables easy adjustment of your screen position, with +45°/-45° swivel, +45°/-45° tilt, and full 360° rotation. The structure offers smooth, effortless rotating and positioning in any direction, so it's easy to reduce glare and find the ideal viewing angle. The micro-adjustment features enable the level alignment of your four monitors. You can also adjust the height of the monitors along the 32.2" (818 mm) pole.
The quad-monitor stand is engineered with heavy-duty steel and aluminum and features a solid steel base. The surface finish features a powder coating to resist scratches. To help keep your work area free of clutter, the monitor stand also features cable clips that keep your cables neatly out of sight.
  • Robust construction
    Made from heavy-duty steel and aluminum, this stand ensures stability while accommodating multiple monitors.
  • Versatile adjustments
    Features height adjustment along with tilt, swivel, and rotation options for personalized viewing angles.
  • Integrated cable management
    Helps to keep cables organized and out of sight, contributing to a tidy workspace and improved productivity.
  • Desktop placement
    Designed as a desktop stand that maximizes desk space while providing a secure base for multiple monitors.
  • Easy installation
    Assembly is straightforward, with all required mounting hardware included to facilitate a quick setup.
Startech Quad Monitor Stand - Articulating - Supports Monitors 13" to 27" - Adjustable VESA Four Monitor Stand for 4 Screen Setup - Steel - Black (ARMBARQUAD) stand - for 4 monitors - black
Stand - desktop stand
31.6 cm x 81.8 cm x 88.5 cm
Tilt
-45° to 45°
Pan
-90° to 90°
Rotation
360°
Adjustments
Height, tilt, swivel, rotation
8.6 kg
Recommended Use
4 monitors
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Aluminium, heavy duty steel
Package Content
Mounting hardware
5-year warranty
P/N: ACCSMNT
31.6 cm
81.8 cm
88.5 cm
8.6 kg
Material
Package Content
Mounting hardware
AV Furniture
Stand
Recommended Use
4 monitors
Placing / Mounting
Desktop stand
Cable Management
13"-27"
Tilt
-45° to 45°
Pan
-90° to 90°
Rotation
360°
Adjustments
Max Load Weight
8 kg
Assembly Required
Limited warranty - 5 years
P/N: ACCSMNT
CRXY StarTech.com Thin Client Mount - VESA In Stock £23.04
CRXY StarTech.com Quad Monitor Mount - Premium - For up to 27" VESA Monitors In Stock £395.70
CRXY StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
CRXY StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
CRXY StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.54
CRXY StarTech.com Six-Monitor Desk Mount/Max 32" In Stock £277.24
