StarTech.com Quad-Monitor Stand - For up to 32" VESA Mount Monitors
Quicklinx: FGFXWS00 Mfr#: ARMQUADSS
Hurry, only 1 left in stock!
£199.53 ex VAT
£239.43 inc VAT
Boost productivity and customize your workspace with this quad-monitor stand, suspending four monitors above your desk. Enjoy optimum viewing with four articulating monitor arms, providing a wide range of motion. The free-standing base gives you flexibility in placing your setup within your workspace.
Constructed of aluminum and steel, the heavy-duty four-monitor stand lets you set up your workspace for optimum productivity. The monitor stand supports four VESA mount (75x75, 100x100) monitors up to 32" each, with a maximum weight capacity of up to 17.6 lb./8 kg per display.
Create a multi-monitor workstation that works best for you. Take advantage of four-screen efficiency for financial analysis, web coding, video editing or many other applications. Customize your setup by adjusting your display height, position and viewing angles for an ergonomic workspace. The swiveling arms provide maximum viewing flexibility.
Place your monitors at the ideal height. Simply adjust the display height along the 34" (864 mm) pole. Align your monitors with the micro-adjustment feature.
The four-screen monitor stand lets you extend the articulating arms up to 16.6" (42.2 cm) to position your monitors in the ideal position. Tilt your monitors +90/-40 degrees and swivel 360 degrees. Rotate your displays 360 degrees for portrait or landscape viewing.
Neatly route your cables with the cable-management channels.
  • Keep?cables?out of view
  • Create a?more?ergonomic?workspace
    Create a multi-monitor workstation that works best for you. Take advantage of four-screen efficiency for financial analysis, web coding, video editing or many other applications. Customize your setup by adjusting your display height, position and viewing angles for an ergonomic workspace.?The?swiveling?arms?provide?maximum viewing flexibility.
  • Height-adjustable?monitor mount
    Place your monitors at the ideal height.?Simply adjust the?display height along the?34" pole.?Align your monitors with the micro-adjustment feature.
StarTech.com Desktop Quad Monitor Stand, Ergonomic VESA 4 Monitor Arm (2x2) up to 32", Free Standing Articulating Universal Pole Mount, Height Adjustable/Tilt/Swivel/Rotate, Silver - Heavy-duty VESA Mount (ARMQUADSS) stand - adjustable arm - for 4 monitors
Stand (adjustable arm) - desktop stand
34.8 cm x 55.3 cm x 12.5 cm
Tilt
-40° to 90°
Rotation
360°
Swivel
360°
Adjustments
6.9 kg
Recommended Use
4 monitors
Recommended Display Size
32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Aluminium, steel
Package Content
16 x washers, hex key (3mm), 4 x VESA monitor mounts, hex key (6mm), 2 x cable-management clips, lower pole, base, upper pole, pole connector, 4 x swivel arms, 16 x M4x16 screws, 16 x M4x12 screws, 16 x M5x16 screws, 16 x M5x12 screws, 16 x M4x20 screws, 16 x M5x20 screws, 32 x spacers, 2 x shoulders
5-year warranty
34.8 cm
55.3 cm
12.5 cm
6.9 kg
Material
Aluminium, steel
Package Content
AV Furniture
Stand
Design
Adjustable arm
Recommended Use
4 monitors
Placing / Mounting
Desktop stand
Cable Management
Integrated cable management
32"
Tilt
-40° to 90°
Rotation
360°
Swivel
360°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
55.5 cm x 35 cm x 13 cm / 7.4 kg
Limited warranty - 5 years
