StarTech.com Quad Monitor Mount - Premium - For up to 27" VESA Monitors
Quicklinx: FLX8WS00 Mfr#: ARMQUADPS
£386.05 ex VAT
£463.26 inc VAT
Four Monitor Mount , Desk/Grommet Mount Tool-less Assembly , For Up to 27" Monitors. Create a highly productive ergonomic workspace with this premium quad monitor mount, supporting four monitors up to 27" each. Four articulating monitor arms feature dual-swivel action, providing a wide range of motion side to side. The attractive silver finish enhances the aesthetics of your workspace.
Enjoy a Wide Range of Motion with Four Displays
The full motion monitor mount lets you maximize your productivity and work in comfort. Each of the four articulating monitor arms extends a full 16.5" (420 mm) and offer a wide range of motion on several axes. Adjust the position of each screen effortlessly as you work.
Sleek and Stable Aluminum Design
Made of robust aluminum, the four-monitor setup provides stable support for VESA compatible monitors (75x75, 100x100) with a weight capacity of up to 24.8 lb. (11.25 kg) per display. The cable-management channel helps to keep your workstation neat and tidy.
Adjust your Viewing Angle
Share your screen with ease. The four arm monitor mount offers a full +180-degree / -180-degree pan, to move your screen left or right. It tilts freely +90 / -15 degrees to adjust the angle up or down. Rotate your screens for landscape or portrait viewing.
Height Adjustment
Work in comfort. This height adjustable monitor mount lets you raise or lower the monitor arms along the 708 mm (27.9") pole.
Tool-less Assembly
The fully assembled desk clamp and pole, plus quick slide-and-click connections, ensure easy assembly. It also saves time when setting up multiple units. The four screen mount gives you the option of desk clamp or grommet hole mounting (hardware included).
The TAA compliant ARMQUADPS is backed by a StarTech.com 10-year warranty and free lifetime technical support.
  • Enjoy a Wide Range of Motion with Four Displays
    The articulating monitor mount lets you maximize your productivity and work in comfort. Each of the?four articulating monitor arms?extends a full 16.5" (420 mm) and offer a wide range of motion on several axes. Adjust?the position of each screen effortlessly as you work.
  • Sleek and?Stable?Aluminum Design
    Made of robust?aluminum, the four-monitor setup provides stable?support for VESA compatible monitors?(75x75, 100x100)?with a weight capacity of?up to?24.8 lb. (11.25 kg) per display.?The?cable-management channel?helps to?keep your workstation neat?and tidy.
  • Adjust your?Viewing?Angle
    Share your screen with?ease.?The?four arm monitor mount?offers a full +180-degree?/ -180-degree?pan, to move your screen left or right.?It tilts freely +90?/ -15?degrees?to adjust the angle?up or down.?Rotate your screens?for landscape or portrait viewing.
  • Height Adjustment
    Work in comfort. This?height adjustable monitor mount?lets you raise or lower the monitor arms along the 708 mm (27.9") pole.
  • Tool-less Assembly
    The fully?assembled desk clamp and pole,?plus?quick slide-and-click connections,?ensure?easy assembly. It?also?saves time when setting up multiple units.?The?four screen?mount?gives you the option of?desk clamp or grommet hole mounting?(hardware included).? The TAA compliant?ARMQUADPS?is backed by a StarTech.com?10-year warranty and free lifetime technical support.
StarTech.com Desk Mount Quad Monitor Arm, Premium Articulating VESA 4 Monitor Mount 2x2 up to 27", Ergonomic Height Adjustable Pole Mount, Tilt/Swivel/Rotate, C-Clamp/Grommet, Silver - Heavy-duty VESA Mount (ARMQUADPS) mounting kit - adjustable arm - for 4 monitors - silver - TAA Compliant
Mounting kit (adjustable arm) - desk-mountable
70.8 cm x 21 cm x 34.5 cm
Tilt
-15° to 90°
Rotation
-180° to 180°
Swivel
-180° to 180°
Adjustments
Height, tilt, swivel, rotation
12.5 kg
Recommended Use
4 monitors
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Material
Aluminium
Silver
TAA Compliant
Package Content
4 x cable management clips, 4 x M5x14 screws, 4 x VESA monitor mounts, EVA pad, grommet mount plate, pole assembly, 2 x shoulders, 8 x swivel arms, 16 x screws, 4 x M3 hex keys
5-year warranty
70.8 cm
21 cm
34.5 cm
12.5 kg
Material
Aluminium
Silver
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
4 monitors
Placing / Mounting
Desk-mountable
Cable Management
Integrated cable management
13"-27"
Tilt
-15° to 90°
Rotation
-180° to 180°
Swivel
-180° to 180°
Adjustments
Max Load Weight
11.3 kg
TAA Compliant
Dimensions & Weight Details
27 cm x 88.5 cm x 34.5 cm / 12.7 kg
Limited warranty - 5 years
FLX8 StarTech.com Thin Client Mount - VESA In Stock £22.48
FLX8 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £50.12
FLX8 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
FLX8 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
