Get fast, high-bandwidth connectivity with this QSFP+ server network card. The converged network adapter adds an open QSFP+ slot to your server or workstation. The 40Gb NIC features an Intel controller and provides reliable performance. It's ideal for high-demand database servers, virtualized servers and agile data centers that require infrastructure updates with no downtime.
This QSFP+ server NIC lets you take advantage of the speed and stability of a 40 Gigabit Ethernet network, with data transfers of up to 40Gbps.
With an open QSFP+ slot, the network interface card supports QSFP+ transceiver modules and is compatible with multimode and single-mode fiber, providing a scalable networking solution.
The 40Gb NIC uses an Intel XL710 chipset, providing reliable connectivity and convergent network features. It offers many advanced features including Intel Virtualization Technology for Connectivity.
Increase Your Network Speed
This QSFP+ server NIC lets you take advantage of the speed and stability of a 40 Gigabit Ethernet network, with data transfers of up to 40Gbps. -
Add Scalable Network Connections
With an open QSFP+ slot, the network interface card supports QSFP+ transceiver modules and is compatible with multimode and single-mode fiber, providing a scalable networking solution. -
Enhance Your Network Capabilities
The 40Gb NIC uses an Intel XL710 chipset, providing reliable connectivity and convergent network features. It offers many advanced features including Intel Virtualization Technology for Connectivity. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Mac Address Pass-Through Utility : To improve network security. •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com Dual Port 40G QSFP+ Network Card, Intel XL710 Open QSFP+ Converged Adapter, PCIe 40 Gigabit Ethernet Server NIC, 40GbE Fiber Optic LAN Card, Dell PowerEdge HPE ProLiant, 40Gb - Network Interface Card (PEX40GQSFPI) - network adapter - PCIe 3.0 x8 - 40 Gigabit QSFP+ x 1
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 3.0 x8
- PCI Specification Revision
- PCIe 3.0
- Ports
- 12.1 cm x 18.1 cm x 2 cm
- 112 g
- Cabling Type
- Ethernet 40GBASE-SR4, Ethernet 40GBase-LR4
- Data Link Protocol
- 40GbE
- Capacity
- Jumbo frame size: 9000
- IPv4, IPv6
- Processor
- Intel
- IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ba
- Black
- System Requirements
- Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x (64-bit) LTS versions
- 2-year warranty
- Network adapter
- Form Factor
- PCIe 3.0
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 40 Gigabit Ethernet
- Capacity
- IPv4, IPv6
- Status Indicators
- Link/activity
- Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support, Link Aggregation, VLAN Tagging
Processor / Memory
- Processor
- Intel
- 1 x 40GBase-LR4/40GBase-SR4 - QSFP+ - female
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Black
- OS Required
- 12.1 cm
- 18.1 cm
- 2 cm
- 112 g
- Shipping Weight
- 200 g
- Limited warranty - 2 years
- 0 °C
- 57 °C
- 5 - 95%
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £146.10 |
StarTech.com 1-Port GbE SFP Network Card | In Stock | £88.55 |
StarTech.com 2-Port GbE SFP Network Card | In Stock | £116.39 |
StarTech.com 4-Port GbE SFP Network Card | In Stock | £190.95 |
