Troubleshoot your wiring problems, quickly and affordably with StarTech.com's REMOTETEST, a specially designed network wire tester that saves valuable time and effort when testing RJ45, RJ11 and BNC cables.
Versatile connectivity
Equipped with a wide range of connectors including 4-pin USB Type-A, 4-pin USB Type-B, BNC, RJ-11, and RJ-45, this device ensures compatibility with a variety of cable types, making it a valuable tool for professionals. -
Comprehensive testing capabilities
This network tester is designed to efficiently identify issues with your cables, offering tests for opens and shorts. Its compatibility with copper media makes it a valuable tool for troubleshooting network problems.
- StarTech.com Professional Multi Function RJ45 RJ11 USB and BNC Cable Tester - network tester
- Network tester
- Tests, Tools and Measurements
- Tests for shorts, tests for opens
- 11 cm x 18 cm x 2.5 cm
- 250 g
- 2 years
- Network tester
- Media
- Copper
- Included Accessories
- Soft case
- Connectors
- BNC, RJ-45 x 2, 4 pin USB type A, 4 pin USB type B, RJ-11 x 2
- RoHS
- Warranty
- 2 years
- Technology
- Alkaline
- Voltage
- 9 V
- Included Qty
- 1
- Required Qty
- 1
- 11 cm
- 18 cm
- 2.5 cm
- 250 g
StarTech.com 20-Bit Electric Precision Screwdriver Set | In Stock | £45.01 |
StarTech.com 55-Bit Electric Precision Screwdriver Set | In Stock | £62.38 |
StarTech.com Temperature/Humidity Meter | In Stock | £24.79 |
StarTech.com Handheld Sound Level Meter | In Stock | £27.14 |
