The Magnetic Privacy Screen for 16-Inch 16:10 Laptop by StarTech.com offers privacy protection with a unique 2-way design, ensuring that information remains confidential while using your device in public spaces. Designed with convenience in mind, this removable filter uses a magnetic installation method that allows for easy and quick application without causing damage to the screen. Complete with a wiping cloth, metal strip, and protective sleeve, it is easy to store and maintain.
This privacy screen provides a protective barrier against prying eyes and features elements such as Microlouver technology, which restricts visibility from certain angles up to +/- 30°. The product is reversible, offering a glossy or matte finish based on user preference. With benefits like a fingerprint-resistant coating and 51% blue light reduction, the Magnetic Privacy Screen enhances comfort and protects eyes during extended use.
Effective privacy protection
A unique 2-way design helps maintain privacy, safeguarding sensitive information from view regardless of the angle of observation. -
Convenient magnetic installation
This filter can be easily attached and removed thanks to its magnetic design, making it simple to switch between using and storing. -
Reversible glossy and matte finish
Users can choose between a glossy or matte side, providing flexibility to suit different environments and preferences. -
Advanced Microlouver technology
Allows only a limited viewing angle of +/- 30°, significantly reducing the chances of onlookers seeing the screen content. -
Additional eye comfort features
A fingerprint-resistant coating and 51% blue light reduction help improve visual comfort during prolonged screen time.
- StarTech.com Magnetic Privacy Screen For 16-Inch 16:10 Laptop, TAA - notebook privacy filter (horizontal) - TAA Compliant
- Product Type
- Notebook privacy filter (horizontal) - 2-way
- Installation Type
- Removable - magnetic
- Package Content
- Wiping cloth, metal strip, protective sleeve
- Black
- Product Material
- Polyethylene terephthalate (PET)
- 22.4 cm x 34.8 cm
- 5 g
- Display Screen Size Compatibility
- 16"
- 51% blue light reduction, +/- 30° visible angle, Microlouver technology, 65% light transmittance, reversible, anti-glare, fingerprint-resistant coating, easy & quick installation, glossy/matte side reversible
- TAA Compliant
- 2-year warranty
- Product Type
- Product Material
- Package Content
- 22.4 cm
- 34.8 cm
- Thickness
- 0.04 cm
- 5 g
- Shipping Dimensions (WxDxH) / Weight
- 26 cm x 38.5 cm x 0.5 cm / 212 g
- 16"
- Black
Display Filter
- Privacy Protection
- 2-way
- Installation Type
- TAA Compliant
- Limited warranty: - 2 years
StarTech.com Privacy Screen 13.3" Laptop | In Stock | £32.44 |
StarTech.com Privacy Screen For 14" Laptop | In Stock | £32.62 |
StarTech.com Privacy Screen For 16" Laptop
