StarTech.com Privacy Screen For 16" Laptop
Quicklinx: J1MDWS00 Mfr#: 161LM-PRIVACY-SCREEN
26 In Stock
£47.44 ex VAT
£56.92 inc VAT
The Magnetic Privacy Screen for 16-Inch 16:10 Laptop by StarTech.com offers privacy protection with a unique 2-way design, ensuring that information remains confidential while using your device in public spaces. Designed with convenience in mind, this removable filter uses a magnetic installation method that allows for easy and quick application without causing damage to the screen. Complete with a wiping cloth, metal strip, and protective sleeve, it is easy to store and maintain.
This privacy screen provides a protective barrier against prying eyes and features elements such as Microlouver technology, which restricts visibility from certain angles up to +/- 30°. The product is reversible, offering a glossy or matte finish based on user preference. With benefits like a fingerprint-resistant coating and 51% blue light reduction, the Magnetic Privacy Screen enhances comfort and protects eyes during extended use.
  • Effective privacy protection
    A unique 2-way design helps maintain privacy, safeguarding sensitive information from view regardless of the angle of observation.
  • Convenient magnetic installation
    This filter can be easily attached and removed thanks to its magnetic design, making it simple to switch between using and storing.
  • Reversible glossy and matte finish
    Users can choose between a glossy or matte side, providing flexibility to suit different environments and preferences.
  • Advanced Microlouver technology
    Allows only a limited viewing angle of +/- 30°, significantly reducing the chances of onlookers seeing the screen content.
  • Additional eye comfort features
    A fingerprint-resistant coating and 51% blue light reduction help improve visual comfort during prolonged screen time.
StarTech.com Magnetic Privacy Screen For 16-Inch 16:10 Laptop, TAA - notebook privacy filter (horizontal) - TAA Compliant
Notebook privacy filter (horizontal) - 2-way
Installation Type
Removable - magnetic
Package Content
Wiping cloth, metal strip, protective sleeve
Product Material
Polyethylene terephthalate (PET)
22.4 cm x 34.8 cm
5 g
Display Screen Size Compatibility
16"
51% blue light reduction, +/- 30° visible angle, Microlouver technology, 65% light transmittance, reversible, anti-glare, fingerprint-resistant coating, easy & quick installation, glossy/matte side reversible
TAA Compliant
Product Material
Package Content
22.4 cm
34.8 cm
Thickness
0.04 cm
5 g
26 cm x 38.5 cm x 0.5 cm / 212 g
16"
Display Filter
Privacy Protection
2-way
Installation Type
TAA Compliant
Limited warranty: - 2 years
J1MD StarTech.com Privacy Screen 13.3" Laptop In Stock £31.64
J1MD StarTech.com Privacy Screen For 14" Laptop In Stock £32.33
