Enhance the privacy of your laptop with the Magnetic Privacy Screen designed for 14-inch displays. This privacy filter utilizes Microlouver technology to provide 2-way privacy protection, ensuring your sensitive information remains confidential from prying eyes. With a removable and easy-to-install magnetic setup, this privacy screen can be effortlessly applied and removed when needed, making it an ideal accessory for anyone on the go. Constructed from durable polyethylene terephthalate (PET), the filter is designed with a fingerprint-resistant coating and boasts anti-glare features, contributing to an improved viewing experience. Transition between glossy and matte finishes with its reversible design, while benefiting from 51% blue light reduction that helps to reduce eye strain. Included with the privacy screen are a wiping cloth, metal strip for secure mounting, and a protective sleeve for safe storage.
Effective privacy protection
This privacy filter uses Microlouver technology to restrict visibility to a +/- 30° angle, ensuring that only the user can view the screen while keeping sensitive information secure from those around. -
Convenient removable design
The magnetic installation allows for simple application and removal of the privacy screen, making it easy to switch between privacy needs and sharing your display. -
Enhanced viewing experience
Equipped with anti-glare and a fingerprint-resistant coating, this privacy filter ensures clear visibility and a clean screen, reducing distractions caused by reflections and smudges. -
Reversible functionality
The privacy screen features a glossy side and a matte side which can be swapped based on personal preference, providing versatility in appearance and usability. -
Eye comfort features
With a 51% blue light reduction capability, this product minimizes eye strain during long working sessions, ideal for professionals and students who require prolonged screen time.
- StarTech.com Magnetic Privacy Screen For 14-Inch 16:9 Laptop, TAA - notebook privacy filter (horizontal) - TAA Compliant
- Product Type
- Notebook privacy filter (horizontal) - 2-way
- Installation Type
- Removable - magnetic
- Package Content
- Wiping cloth, metal strip, protective sleeve
- Black
- Product Material
- Polyethylene terephthalate (PET)
- 18.4 cm x 31.3 cm
- 5 g
- Display Screen Size Compatibility
- 14"
- 51% blue light reduction, +/- 30° visible angle, Microlouver technology, 65% light transmittance, reversible, anti-glare, fingerprint-resistant coating, easy & quick installation, glossy/matte side reversible
- TAA Compliant
- 2-year warranty
- Product Type
- Product Material
- Package Content
- 18.4 cm
- 31.3 cm
- Thickness
- 0.04 cm
- 5 g
- Shipping Dimensions (WxDxH) / Weight
- 26 cm x 38.5 cm x 0.5 cm / 202 g
- 14"
- Black
Display Filter
- Privacy Protection
- 2-way
- Installation Type
- TAA Compliant
- Limited warranty: - 2 years
StarTech.com Privacy Screen 13.3" Laptop | In Stock | £33.46 |
StarTech.com Privacy Screen For 16" Laptop | In Stock | £51.42 |
