StarTech.com Privacy Screen Dell U3824DW
Quicklinx: J9X1WS00 Mfr#: 38C29-PRIVACY-SCREEN
11 In Stock
£154.15 ex VAT
£184.98 inc VAT
This privacy screen is designed for the curved 38-inch Dell U3824DW 21:9 ultrawide monitor, effectively obscuring sensitive on-screen information and ensuring that both the center and outer edges of the screen are shielded from unwanted views. The privacy shield obscures the computer's screen from the sides while providing an approximate viewing angle of 60 degrees (+/- 30 degrees from the center) to the user. The security shield also features blue light reduction, blocking between 40% to 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. The privacy shield has a light transmittance of 65% providing optimal screen brightness and enhanced levels of privacy. The privacy screen protector is double-sided, with a matte anti-glare side for environments prone to glare and a high-gloss side that helps retain color vibrancy. Easily install the glossy or matte side of the privacy screen protector using the included adhesive strips; Optional mounting tabs are included for additional support on lower bezel. Note: Before installation, ensure the side of the filter that is intended to face outward has been selected. Please note that once applied, the adhesive strips form a strong bond that makes removal and reinstallation difficult.
StarTech.com display privacy filter - 38" (ultra-wide) - TAA Compliant
Display privacy filter - 2-way
Installation Type
Removable - plug-in/adhesive
Package Content
2 adhesive strips, slide mount tabs, wiping cloth
Display Screen Size Compatibility
38" (ultra-wide)
89.39 cm x 37.65 cm x 0.03 cm
214 g
TAA Compliant
Package Content
38" (ultra-wide)
89.39 cm - 37.65 cm - 0.03 cm
214 g
95.2 cm x 45 cm x 0.5 cm / 700 g
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
21:9
Surface Finish
Glossy/matte
Scratch Resistant
Mounting Kit
Included
Horizontal orientation, compatible with curved screen, microlouver privacy technology, +/- 30° visible angle, 51% blue light reduction, 65% light transmittance, fingerprint-resistant coating, glossy surface, anti-glare, 60° visible angle, double-sided, Hassle-free installation
TAA Compliant
J9X1 StarTech.com Privacy Screen Adhesive Strips In Stock £6.33
